Which SWF files control appearance?
Guest
Feb 28, 2007 Feb 28, 2007
After publishing a SCORM Breeze file, I want to change the appearance of the skins and background without having to re-publish the PPT file. Are there SWF files that I can copy and paste from another, correctly published, project? If so, which SWF files are they?
Presenter
342
Guest
Mar 01, 2007 Mar 01, 2007
Oak,
One way to modify the "theme" applied to a published presentation is to massage the vconfig.xml document.
It can be found in the data directory of a published ppt deck. Open vconfig.xml in Notepad, for example, and what you're looking for is found at the top of the document. Specifically, look for the <colors> node in the xml and you should see 6 tags related to the interface colors, which are all identified by the <uicolor> tag. The block of information should look similar to this:
<uicolor name="primary" value="0x######"/>
<uicolor name="glow" value="0x######"/>
<uicolor name="text" value="0x######"/>
<uicolor name="light" value="0x######"/>
<uicolor name="shadow" value="0x######"/>
<uicolor name="background" value="0x######"/>
Couple of things:
1. the # symbol that I included here references hexadecimal color code typically used in HTML, XML , etc. You do not want to eliminate or change the 0 that precedes the x as in 0x#######, or color changes that you make here will end up with less than desirable results.
2. regarding the "name" attributes:
Primary controls the way that the main panels in Breeze are displayed. This references the Notes, Outline and Playback/Nav area of the Breeze content interface.
Glow does what it says: it creates the outer glow on clickable elements such as the play/pause button, paperclip icon, etc.
Text also does what it says: allows you to change the color of your text of the Breeze panels.
Light references the highlight bar that is displayed in the Navigation/Outline and the Thumbnail panels when you're on a specific "slide" in the presentation.
Background controls the background gradient behind the ppt slides.
Hope that helps!
Best,
Rob
Guest
Mar 02, 2007 Mar 02, 2007
Thanks Rob, that did the trick!
Help resources
