I'm publishing my RoboHelp 9 projects in IIS (Windows Server) and the index tree is gone if I open them in Chrome version 28.0.1500.72 m
If I apply the fix (WebHelp TOC does not display using Google's Chrome Browser) suggested here http://www.grainge.org/pages/snippets/snippets.htm#browsers
it looks like it fixes the problem for European languages but it breaks the search functionality for Asian languages.
Any idea?
Thank you
The fix does say it is only for Rh7.
Could it be like Item 6 at http://www.grainge.org/pages/snippets/snippets.htm#webhelp. You haven't said if the problem is only with Chrome.
Try publishing from the sample projects. That will identify whether it is a general or project issue.
Thank you Peter for your prompt reply.
Yes, the problem is only with Chrome, and specifically the last version. The projects were working fine in Chrome version 27.
I checked and the mime types are set up correctly on IIS, so that has to be excluded as a problem.
Do you know if there is any fix for RH 9 whver.js file to apply for Chrome?
We have many projects published in different languages, and never a problem with the TOC, but I'll try to publish a sample project.
The fix would have been included in later versions so I am guessing the Chinese search problem was not picked up the original fix.
I can only suggest contacting Adobe Tech Support. It may be they are aware of the issue and have a fix.
