why does <br style="page-break-before: always;"> get replaced with <br class="hcp10">
This issue only occurs when generating an HTML Help CHM file.
An alternative method can be found in Item 23 at http://www.grainge.org/pages/snippets/snippets.htm#content.
Are you saying the code in the source file gets changed? I suspect you mean target files but how are you identifying the change in a CHM? Is the change causing a problem?
I have edited the title to remove the HTML as that causes issues with RSS feeds etc.
Please take a look at the Before You Post thread. What version of Rh are you using?
Thanks for the reply!
I'm using Rh 10.0.1.292
Your recommendation worked - thank you!
I open the source code in the CHM page and see that page breaks differ on certain pages.
The change causes the printout to be continuous, which is not what I want.
Thanks for you help!
