I've searched google for hours, and have read quite a bit of useful information, but unfortunately it did not work for me. so here is my problem.
I just restored my pc, installed only what I needed for my pc to work right now, video drivers, browsers, etc. I install the latest version of flash. every page i go too, it will not show my videos.
I'm running windows 7 54 bit, Firefox 7.0, IE 9. firefox shows in my add on's that I do have flash installed, it's enabled, and should be working. but it doesn't. even when I go to adobe's page I don't see the animations I'm suppose to see.
I've uninstalled and reinstalled different versions of flash. and still nothing works. I'm not getting any errors that it didn't install correctly. and I haven't installed my antivirus software yet, but Will once I get everything sorted out, so It couldn't be that.
any help you can give me I would greatly appreciate it. and any more info you need, I will do my best to give you that as well.
thanks
Firefox 7.0 is fifteen (15) versions obsolete. They're on 22 now. http://www.mozilla.org/en-US/firefox/new/
That would be a start
I stick with this version because I know it works with all my add on's and never had a problem with it. I restored my pc 2 days ago, and had the same version installed, with the up to date flash. and never had any issues with it.
I assume if it worked fine before it should do the same, but If I need to get the latest firefox update then I will, but It still won't work with IE 9.
If the latest Flash Player WON'T work with your Firefox (and it won't - see below),
and you NEED the latest Flash Player to view content on the web...
then you have the choice to update your browser, or stop viewing Flash content.
Per http://www.adobe.com/products/flashplayer/tech-specs.html
It could be caused by an outdated graphics driver; see http://forums.adobe.com/thread/945765
yes I do have the latest update on my video card. that was priority one when I restored everything lol. I'm starting to wonder if I just had a bad restore? and maybe I should do it again?
