1. Re: Automatically re-link layer masks
c.pfaffenbichler Aug 17, 2012 7:21 AM (in response to scottyharland6)Seems xbytor has offered a tutorial on determining if a Layer Mask is linked:
2. Re: Automatically re-link layer masks
c.pfaffenbichler Aug 17, 2012 8:00 AM (in response to scottyharland6)This could work for Layer Masks, but not Vector Masks.
// 2012; use it at your own risk; #target photoshop if (app.documents.length > 0) { linkLayerMasks(app.activeDocument) }; ////// link all layer masks ////// function linkLayerMasks (theParent) { for (var m = theParent.layers.length - 1; m >= 0;m--) { var theLayer = theParent.layers[m]; app.activeDocument.activeLayer = theLayer; var ref = new ActionReference(); ref.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") ); var layerDesc = executeActionGet(ref); var layerMaskLinked = layerDesc.getBoolean(layerDesc.getKey(10)); // link if unlinked; if (layerMaskLinked == false) { var idsetd = charIDToTypeID( "setd" ); var desc4 = new ActionDescriptor(); var idnull = charIDToTypeID( "null" ); var ref2 = new ActionReference(); var idLyr = charIDToTypeID( "Lyr " ); var idOrdn = charIDToTypeID( "Ordn" ); var idTrgt = charIDToTypeID( "Trgt" ); ref2.putEnumerated( idLyr, idOrdn, idTrgt ); desc4.putReference( idnull, ref2 ); var idT = charIDToTypeID( "T " ); var desc5 = new ActionDescriptor(); var idUsrs = charIDToTypeID( "Usrs" ); desc5.putBoolean( idUsrs, true ); var idLyr = charIDToTypeID( "Lyr " ); desc4.putObject( idT, idLyr, desc5 ); executeAction( idsetd, desc4, DialogModes.NO ); }; // apply the function to layersets; if (theLayer.typename == "ArtLayer") {} else { linkLayerMasks(theLayer) } } }; -
3. Re: Automatically re-link layer masks
c.pfaffenbichler Aug 17, 2012 8:18 AM (in response to scottyharland6)I guess one could simply add a try-clause with the ScriptingListener-code for linking Vector Masks in the function
linkLayerMasks… -
4. Re: Automatically re-link layer masks
Paul Riggott Aug 17, 2012 9:21 AM (in response to scottyharland6)Here is another version, this does not open any layersets, and should be faster as it references the layers rather than making active each one.
#target photoshop app.bringToFront(); main(); function main(){ if(!documents.length) return; linkLayers(); } function linkLayers(){ var ref = new ActionReference(); ref.putEnumerated( charIDToTypeID('Dcmn'), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') ); var count = executeActionGet(ref).getInteger(charIDToTypeID('NmbL')) +1; var Names=[]; try{ activeDocument.backgroundLayer; var i = 0; }catch(e){ var i = 1; }; for(i;i<count;i++){ if(i == 0) continue; ref = new ActionReference(); ref.putIndex( charIDToTypeID( 'Lyr ' ), i ); var desc = executeActionGet(ref); var layerName = desc.getString(charIDToTypeID( 'Nm ' )); var Id = desc.getInteger(stringIDToTypeID( 'layerID' )); if(layerName.match(/^<\/Layer group/) ) continue; if(desc.hasKey(charIDToTypeID("UsrM"))) link(i); } }; function link(idx){ var desc = new ActionDescriptor(); var ref = new ActionReference(); ref.putIndex( charIDToTypeID( "Lyr " ), idx ); desc.putReference( charIDToTypeID('null'), ref ); var desc2 = new ActionDescriptor(); desc2.putBoolean( charIDToTypeID('Usrs'), true); desc.putObject( charIDToTypeID('T '), charIDToTypeID('Lyr '), desc2 ); executeAction( charIDToTypeID('setd'), desc, DialogModes.NO ); }; -
5. Re: Automatically re-link layer masks
c.pfaffenbichler Aug 18, 2012 3:25 AM (in response to Paul Riggott)Not surprisingly Paul’s Script is neater.
6. Re: Automatically re-link layer masks
scottyharland6 Aug 20, 2012 1:51 AM (in response to scottyharland6)Thanks very much for the help - i'll give it a shot
7. Re: Automatically re-link layer masks
lister110 Jul 25, 2013 9:49 AM (in response to scottyharland6)Is there a script that also does the Vector mask as well? This is great by the way..
8. Re: Automatically re-link layer masks
Michael L Hale Jul 25, 2013 10:36 AM (in response to lister110)main(); function main(){ if(!documents.length) return; linkLayers(); } function linkLayers(){ var ref = new ActionReference(); ref.putEnumerated( charIDToTypeID('Dcmn'), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') ); var count = executeActionGet(ref).getInteger(charIDToTypeID('NmbL')) +1; var Names=[]; try{ activeDocument.backgroundLayer; var i = 0; }catch(e){ var i = 1; }; for(i;i<count;i++){ if(i == 0) continue; ref = new ActionReference(); ref.putIndex( charIDToTypeID( 'Lyr ' ), i ); var desc = executeActionGet(ref); var layerName = desc.getString(charIDToTypeID( 'Nm ' )); var Id = desc.getInteger(stringIDToTypeID( 'layerID' )); if(layerName.match(/^<\/Layer group/) ) continue; if(desc.hasKey(charIDToTypeID("UsrM"))) linkChannelMask(i); if(desc.getBoolean(stringIDToTypeID("hasVectorMask"))) linkVectorMask(i); } }; function linkChannelMask(idx){ var desc = new ActionDescriptor(); var ref = new ActionReference(); ref.putIndex( charIDToTypeID( "Lyr " ), idx ); desc.putReference( charIDToTypeID('null'), ref ); var desc2 = new ActionDescriptor(); desc2.putBoolean( charIDToTypeID('Usrs'), true); desc.putObject( charIDToTypeID('T '), charIDToTypeID('Lyr '), desc2 ); executeAction( charIDToTypeID('setd'), desc, DialogModes.NO ); }; function linkVectorMask(idx){ var desc = new ActionDescriptor(); var ref = new ActionReference(); ref.putIndex( charIDToTypeID( "Lyr " ), idx ); desc.putReference( charIDToTypeID( "null" ), ref ); var desc1 = new ActionDescriptor(); desc1.putBoolean( stringIDToTypeID( "vectorMaskLinked" ), true ); desc.putObject( charIDToTypeID( "T " ), charIDToTypeID( "Lyr " ), desc1 ); executeAction( charIDToTypeID( "setd" ), desc, DialogModes.NO ); }Adobe has changed both the way masks work and the layer descriptor over the different Photoshop versions. This works in CC. Should work back to at least CS4.
9. Re: Automatically re-link layer masks
lister110 Jul 25, 2013 2:16 PM (in response to Michael L Hale)I ge an error when executing the script (CS6)
Error 8500: The requested property does not exist.
Line: 19
-> var layerName = desc.getString(charIDToTypeID( 'Nm ' ));
ANy ideas?
10. Re: Automatically re-link layer masks
Michael L Hale Jul 25, 2013 3:46 PM (in response to lister110)It works for me with CS6( 13.1.2 ). And I thought the layer descriptor has always had a name property. All the way back to Photoshop 7.
Does your document have any layerSets? LayerSets should also have that property. But it you are using 13.0 maybe there is a bug. If so I think I know a workaround.
Let me know what version you are using and about the layerSets.
Just in case, the charID should have two spaces. I don't think that the reason as if it doesn't have the right number of chars you should get a different error.
11. Re: Automatically re-link layer masks
lister110 Jul 25, 2013 3:55 PM (in response to Michael L Hale) -
12. Re: Automatically re-link layer masks
Michael L Hale Jul 25, 2013 4:00 PM (in response to lister110)I mean what version of CS6 are you using. It has been updated so there are more than one version named CS6. You can find what version you have in the help menu under about Photoshop.
13. Re: Automatically re-link layer masks
Michael L Hale Jul 26, 2013 8:51 AM (in response to lister110)You could try this. It doesn't use the name property.
main(); function main(){ if(!documents.length) return; linkLayers(); } function linkLayers(){ var ref = new ActionReference(); ref.putEnumerated( charIDToTypeID('Dcmn'), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') ); var count = executeActionGet(ref).getInteger(charIDToTypeID('NmbL')) +1; var Names=[]; try{ activeDocument.backgroundLayer; var i = 0; }catch(e){ var i = 1; }; for(i;i<count;i++){ if(i == 0) continue; ref = new ActionReference(); ref.putIndex( charIDToTypeID( 'Lyr ' ), i ); var desc = executeActionGet(ref); var layerSection = desc.getEnumerationValue(stringIDToTypeID( 'layerSection')); var Id = desc.getInteger(stringIDToTypeID( 'layerID' )); if(typeIDToStringID(layerSection)=='layerSectionEnd') continue; if(desc.hasKey(charIDToTypeID("UsrM"))) linkChannelMask(i); if(desc.getBoolean(stringIDToTypeID("hasVectorMask"))) linkVectorMask(i); } }; function linkChannelMask(idx){ var desc = new ActionDescriptor(); var ref = new ActionReference(); ref.putIndex( charIDToTypeID( "Lyr " ), idx ); desc.putReference( charIDToTypeID('null'), ref ); var desc2 = new ActionDescriptor(); desc2.putBoolean( charIDToTypeID('Usrs'), true); desc.putObject( charIDToTypeID('T '), charIDToTypeID('Lyr '), desc2 ); executeAction( charIDToTypeID('setd'), desc, DialogModes.NO ); }; function linkVectorMask(idx){ var desc = new ActionDescriptor(); var ref = new ActionReference(); ref.putIndex( charIDToTypeID( "Lyr " ), idx ); desc.putReference( charIDToTypeID( "null" ), ref ); var desc1 = new ActionDescriptor(); desc1.putBoolean( stringIDToTypeID( "vectorMaskLinked" ), true ); desc.putObject( charIDToTypeID( "T " ), charIDToTypeID( "Lyr " ), desc1 ); executeAction( charIDToTypeID( "setd" ), desc, DialogModes.NO ); }
