ODoyle,
Perhaps you've solved this problem to your satisfaction.
But for what it's worth, I think I know why you weren't
successful at first.
You probably know that when you "delete" images and baggage
files, RH does not delete them from the project folder. In fact, it
publishes them even when they have no references in any topic. With
the project closed, you need to violate the cardinal rule about
never manipulating project directories in Windows Explorer and
manually move the unused images and baggage files out.
If a red X shows up when you launch the project in RH, that's
an indication the database file needs cleaning up.
Sometimes the RH houskeeping tables get confused.
The project.cpd file is a database for MS Access. Among other
tables, there's one for listing baggage files and another for
baggage file references in topics.
Either:
A. You've totally confused the .cpd tables by all the manual
actions in Windows Explorer, or
B. Something else is happening.
I know the .cpd file preserves the upper-lower case
distinctions. Perhaps the hyphen in the filename is causing a
hiccup somewhere (I know, you should be able to use a hyphen.) But
I prefer an underscore because all apps seem to recognize it as a
valid character.
You may weant to study the .cpd structure. With the project
closed in RH, launch MS Access and open the .cpd file.
Probably you'll get a "harmful files" security warning. I
can't tell you what to do here, but I just click through the
warning and no sirens go off.
You also may be warned that the .cpd file was built under an
earlier version of MS Access and needs to be converted before you
can save any changes. Again, I shouldn't tell you what to do here,
but I also click through this warning. I can edit, add and delete
entries in the tables and save the .cpd. The changes don't get hit.
Maybe there are other things you can't save in the old format, but
table line items seem to work. I'm told it's safe to convert the
.cpd file to the MS Access current version.
One approach is to delete the baggages files, if you can, in
RH. Close the project and delete or move those that remain in the
project folder.
Then (project is still closed) use MS Access to delete any
remaining entries in the two baggage tables. Launch the project in
RH and import the necessary baggage files from outside the project
folder.
Another approach is to study how the tables keep track of
topic references and edit the tables.
By the way, the images list table also may need cleaning up
if you've been moving images around outside of RH. At least, you
can delete the Red X's by editing the images list table.
