I have been wrestllng with an issue for weeks. I have cleaned my registry, run Malware programs, and my machine has AVS on it. I ran Windows Defender, and Norton. I am running a Dell i3 with Windows 7 SP1, IE 10 and Chrome. I have followed all of the on line suggestions, uninstalling, installing a fresh copy, I upgraded the IE to 10, the W7 is current. I have Shockwave enabled, Java is running and if I install a fresh copy of Flash I can go to You Tube and run 1 video and then I start getting errors. This video is not available, You need to upgrade your Flash, This video not availalbe.
I even talked to my computer repair company and they remoted into the machine and completely cleaned it up and as I did again ran all of your suggested repairs. The only thing that is strange is that my computer passes your tests, showing it is installed and the version yet when I look it up in Control Panel, all programs, it isn't there and it doesn't appear in Control Panel either.
You are trying to watch these videos on IE or on Chrome?
For IE you must install the Flash Player ActiveX Control, and it should show up in Programs & Features (under Adobe).
Chrome comes with Flash Player preinstalled; it will not show in Programs and Features.
I have tried to use both IE and Chrome. Neither works. Flash Player has been installed and it does not show up anywhere nor does it work in IE or Chrome.
Do you have the 32-bit or 64-bit edition of Windows 7?
Anyway, go to C:\Windows\system32\Macromed\Flash and tell me what files you have in there.
Also, for IE check
In Chrome check if the Flash Player plugin is enabled.
I am running 64 bit Windows 7
Here are the files:
Name Size Date Modified
activex.vch 1.5 MB 7/26/13 10:31:11 AM
Flash32_11_8_800_94.ocx 15.5 MB 7/26/13 10:31:11 AM
FlashInstall.log 282 kB 7/26/13 10:31:14 AM
FlashPlayerUpdateService.exe 251 kB 7/26/13 10:31:12 AM
FlashUtil32_11_8_800_94_ActiveX.dll 468 kB 7/26/13 10:31:11 AM
FlashUtil32_11_8_800_94_ActiveX.exe 796 kB 7/26/13 10:31:11 AM
mms.cfg 47 B 7/26/13 10:31:12 AM
Are you sure you have the 64-bit edition of Windows 7? The files you listed are all 32-bit.
Do you have a C:\Windows\sysWOW64\Macromed\Flash folder, and what is in there?
Anyway, have you checked if the Flash Player plugin is enabled in your browsers?
Here is what my computer is telling me.
Sorry, if you attached a screenshot, it didn't make it. You need to post screenshots in the forum.
What about C:\Windows\sysWOW64\Macromed\Flash ?
Name Size Date Modified [parent directory] activex.vch 1.5 MB 7/27/13 11:22:40 AM Flash32_11_8_800_94.ocx 15.5 MB 7/27/13 11:22:39 AM FlashInstall.log 301 kB 7/27/13 11:22:42 AM FlashPlayerUpdateService.exe 251 kB 7/27/13 11:22:40 AM mms.cfg 47 B 7/27/13 11:22:40 AM
Your replies do not contain any information. Please go back to your forum topic and post the reply there.
Sorry I am going back and posting the answers right now.
You should be getting everything now. I am posting all the answers.
So far I have followed all of the suggestions you have made with out success. My computer shows that i have the current version of Flash, My computer is running W7 64bit and the current version of Flash when I use the tools. When I look in my computer that doesn't agree.
Yes I have double checked. I also re-installed IE 64 bit.
I have followed thread 885448 and 867968
Chrome plug in is not working
activex.vch
mms.cfg
I have 64 Bit Win 7 SP1 confirmed The files are in another email. I have also gone through threads 885448 and 867968
I have both IE and Chrome and neither is working. I have installed and uninstalled, IE, Chrome and Adobe. Flash does not show up in Programs & Features nor Control Panel.
