Camera Raw 6.7 update (re)offered after 6.7.1
tjhb Jul 28, 2013 6:16 PMHello,
This is a bug report really. Here is the sequence.
Install Adobe CS5 Production Premium.
Install CS5 updates (manually, from downloaded patch files)
Adobe Application Manager 2.0
Adobe Media Encoder CS5 5.0.1
Adobe Player for Embedding 3.1 x86
Adobe Player for Embedding 3.1 x64
After Effects 10.0.2
Bridge 4.0.5
Camera Raw 6.7
CS Live Services update for CS5 2.01
Device Central CS5 3.0.1
Extension Manager 5.0.1
Flash CS5 11.0.2
Illustrator 15.0.2
Photoshop 12.0.5
Pixel Bender toolkit 2.5
Premiere Pro 5.0.3
XMP Panels CS5 3.1
Reboot
Install further CS5 update (again manually)
Camera Raw 6.7.1
Check for updates (using Adobe Application Manager 2.0)
Camera Raw 6.7 is reoffered
Attempting to re-install version 6.7 fails (unsurprisingly) with error U44M1P7.
The installation log for the failed update ends as follows:
Payloads passed preflight validation.
Call PreSession Custom Hook
BEGIN InstallOperationsQueue Unordered operations
{07238EEC-C837-4D4F-BED7-BBB341BC7FE6} Photoshop Camera Raw (64 bit)_6.7_AdobeCameraRaw6.0All-x64 6.7.0.0: with operation none
{4E1B59A1-029E-4C16-BBB3-F10D40EBB6EE} Photoshop Camera Raw_6.7_AdobeCameraRaw6.0All 6.7.0.0: with operation none
END InstallOperationsQueue Unordered operations
[ 3676] Mon Jul 29 12:48:56 2013 ERROR
DW028: InstallOperationsQueue: Instruction set is empty
[ 3676] Mon Jul 29 12:48:56 2013 FATAL
DW028: Unable to open operation queue
[ 3676] Mon Jul 29 12:48:58 2013 INFO
Total components installed: 0
Total components repaired: 0
Total components removed: 0
Call PostSession Custom Hook
:: END TIMER :: [Total Timer] took 10571 milliseconds (10.571 seconds) DTR = 39.7313 KBPS (0.0388001 MBPS)
-------------------------------------- Summary --------------------------------------
- 1 fatal error(s), 3 error(s), 6 warning(s)
ERROR: DW023: The extension payload: {CC43F132-5096-41FC-A5C2-69E4202AC114} Camera Profiles Installer_6.7_AdobeCameraRawProfile6.0All 6.7.0.0 requires a parent with following specification:
Family: Shared Technology
ProductName: Camera Profiles Installer
MinVersion: 0.0.0.0
This parent relationship is not satisfied, because this payload is not present in this session.
This payload will be ignored in this session.
WARNING: DW016: NOTE: Cannot set action to the payload {07238EEC-C837-4D4F-BED7-BBB341BC7FE6} Photoshop Camera Raw (64 bit)_6.7_AdobeCameraRaw6.0All-x64 6.7.0.0 as it is already upgraded by the payload {4FE1A8AA-7449-4A5F-A484-D655D863BC66} Photoshop Camera Raw (64 bit)_6.7.1_AdobeCameraRaw6.0All-x64 6.7.1.0
WARNING: DW016: NOTE: Cannot set action to the payload {4E1B59A1-029E-4C16-BBB3-F10D40EBB6EE} Photoshop Camera Raw_6.7_AdobeCameraRaw6.0All 6.7.0.0 as it is already upgraded by the payload {7B01713A-11C0-40DE-93F7-988A2D8DCA19} Photoshop Camera Raw_6.7.1_AdobeCameraRaw6.0All 6.7.1.0
ERROR: DW028: InstallOperationsQueue: Instruction set is empty
FATAL: DW028: Unable to open operation queue
Please search the above error/warning string(s) to find when the error occurred.
These errors resulted in installer Exit Code mentioned below.
Exit Code: 7 - Unable to complete Silent workflow.
Please see specific errors and warnings for troubleshooting. For example, ERROR: DW023, DW028 ... WARNING: DW016 ...
END - Installer Session
The errors all make perfect sense--the log describes the situation perfectly.
So the only problem is that AAM is offering 6.7 after 6.7.1.
I don't know why this is, of course. But two more observations.
After installing Adobe CC (including the desktop application, so that AAM is replaced), 6.7 is still re-offered (and still fails of course).
After installing 6.7.1 (again manually), 6.7 is still re-offered.
This is all harmless--except that it may be causing a lot of people (not just me) to waste their time, so it would be good if it could be fixed.
Tim Baigent
