1. Re: How to create Black aspect ratio bars like in Final Cut Pro.
JaysonM-Y Jul 28, 2013 7:27 PM (in response to AzzieScott)AzzieScott wrote:
Premeire CC is supposed to make our life easier.
It does but you have an uncanny request. Even when using FCP I don't use 2.XX:X bars. I usually edit in native dimensions then export to whatever dimensions I want and tell compressor to scale or crop the dimensions to fit my export.
You can create your bars with the title tool. One rectangle at the top and the other at the bottom.
3. Re: How to create Black aspect ratio bars like in Final Cut Pro.
AzzieScott Jul 28, 2013 7:35 PM (in response to JaysonM-Y)Now hold on, dont get it confused, I love PP CC way better than FCP but im just suprised that some simple like apsect Ratio Bars are not pre installed.
4. Re: How to create Black aspect ratio bars like in Final Cut Pro.
AzzieScott Jul 28, 2013 7:35 PM (in response to JSS1138)awesome, I will try it. Thank you.
5. Re: How to create Black aspect ratio bars like in Final Cut Pro.
shooternz Jul 28, 2013 8:36 PM (in response to AzzieScott)Instead of bars...why not work in an aspect ratio (of whatever your choice) without fake bars?
Black bars were never part of any film.
IMHO: Its a pseudo aspect ratio effect that is cliche becaused its not correct when done this way.
The alternate way to advice given above is to work in a Custom Sequence. This allows you to pan and scan your footage around to fit (I assume it was not shot 2.35?).
BTW: who ever told you this..
6. Re: How to create Black aspect ratio bars like in Final Cut Pro.
JSS1138 Jul 28, 2013 9:22 PM (in response to shooternz)why not work in an aspect ratio (of whatever your choice) without fake bars?
One reasons is because it may need to be delivered with bars, for example, Blu-ray or DVD.
7. Re: How to create Black aspect ratio bars like in Final Cut Pro.
JaysonM-Y Jul 28, 2013 9:32 PM (in response to JSS1138)But... then you could just export the final file as 1080p or SD and it'll auto scale and give you a file with bars...
8. Re: How to create Black aspect ratio bars like in Final Cut Pro.
AngeloLorenzo Jul 29, 2013 1:42 AM (in response to AzzieScott)Agree with the others: edit in a custom sequence to allow pan & scan. Once you ready yourself for export with Media Encoder, you'll find that it will add black padding to fill the aspect ratio whether it be 16:9 standard HD or 4:3/16:9 SD, and so on.
9. Re: How to create Black aspect ratio bars like in Final Cut Pro.
JSS1138 Jul 29, 2013 8:40 AM (in response to JaysonM-Y)You could. But if the material is 1080, and it was shot with 2.35 framing in mind, it's simpler to just work at 1080 using the effect I posted earlier.
10. Re: How to create Black aspect ratio bars like in Final Cut Pro.
JSS1138 Jul 29, 2013 10:44 AM (in response to AzzieScott) -
11. Re: How to create Black aspect ratio bars like in Final Cut Pro.
Greg Popp Jul 29, 2013 11:05 AM (in response to AzzieScott)As you may need other sizes at some point (for example, "House of Cards" is framed 2.0-1 - that's right, 2-1, as it feels cinematic but doesn't leave as much of one's LCD unused), I fould this tutorial the best out there. The kid sweetly mumbles through it, but for a non-Photoshop user like myself, I found it really easy to follow and make my own. I even had to make a mask for a 1.85 4K file that was cropped 2.35. Enjoy! http://www.youtube.com/watch?v=Rk41-MS2nCk
12. Re: How to create Black aspect ratio bars like in Final Cut Pro.
jamesp2 Jul 29, 2013 11:38 AM (in response to Greg Popp)It's much easier to do this within PPro itself -- just use the crop filter and either make a preset or create a new sequence and add the crop effect to an adjustment layer, then copy that layer into any subsequent sequence.
In both methods, you have to do the rudimentary math, so it's not as if you save yourself anything by going to Photoshop.
And you don't have to listen to that insufferable kid.....
BTW, the aspect ratio filter in FCP was, at least in the earlier versions, a big problem: moving the footage around to reframe it reduced resolution in many cases. The workaround was a garbage matte -- pretty much like the PPro method.
13. Re: How to create Black aspect ratio bars like in Final Cut Pro.
Ann Bens Jul 29, 2013 12:02 PM (in response to jamesp2)And its so easy to make in the Titler for a 1920x1080 sequence.
2 black rectangulars 1080 wide and 132 high (even numbers) placed top and bottom.
Make into template and done.
14. Re: How to create Black aspect ratio bars like in Final Cut Pro.
JSS1138 Jul 29, 2013 3:40 PM (in response to jamesp2)In both methods, you have to do the rudimentary math
Already done and saved as presets in post 2.
15. Re: How to create Black aspect ratio bars like in Final Cut Pro.
joe bloe premiere Jul 29, 2013 3:43 PM (in response to JSS1138)Maybe it's me, I don't get the fascination with 2.35:1.
¯\(°_o)/¯
16. Re: How to create Black aspect ratio bars like in Final Cut Pro.
JSS1138 Jul 29, 2013 3:52 PM (in response to joe bloe premiere)Originally, 2.35:1 movies (updated to 2.39:1 in the 70's and now with MPEG often changed to an exact 2.40:1) were wider than the other cinematic norm - 1.85:1. The curtains on the sides of the theater screen would actually slide over, widening the presentation. Back then, you actually got more screen for your movie.
With fixed resolution digital projection becoming the norm in theaters, we're losing that truly wide screen, and are getting a cropped presentation, with curtains covering up the unused portion for 2.39, rather then revealing more screen like they used to.
Still, the look of the wider screen appeals.
17. Re: How to create Black aspect ratio bars like in Final Cut Pro.
joe bloe premiere Jul 29, 2013 5:02 PM (in response to JSS1138)If it originated in that aspect and needs to conform to 1080, sure.
But to 'emulate' that look by chopping off the top and bottom
of 1080 video seems sorta faddish and semi-pointless.
And if it's only about aesthetics, why the need to be so 'pixel exact'?
(A rhetorical question)
18. Re: How to create Black aspect ratio bars like in Final Cut Pro.
jamesp2 Jul 29, 2013 5:42 PM (in response to joe bloe premiere)joe bloe premiere wrote:
¯\(°_o)/¯
Depends on what tradition of visual aesthetics you come from. The vast majority of Asian films are 2:39:1 because that ratio best reflects Asian pictorial traditions, which emphasized space and expanse over perspective. Kurosawa went to extreme lengths to further eliminate perspective in 2.39:1 -- shooting intimate interiors at huge distances with long lenses.
It's just a question of how you want to paint the picture.
19. Re: How to create Black aspect ratio bars like in Final Cut Pro.
joe bloe premiere Jul 29, 2013 5:44 PM (in response to jamesp2)Ahhh... Asian pictorial traditions.
20. Re: How to create Black aspect ratio bars like in Final Cut Pro.
jamesp2 Jul 29, 2013 5:49 PM (in response to joe bloe premiere)joe bloe premiere wrote:
Ahh.... I forgot. You have to pretend you're just one of the guys on these forums.
21. Re: How to create Black aspect ratio bars like in Final Cut Pro.
joe bloe premiere Jul 30, 2013 7:35 AM (in response to jamesp2)Ahh.... I forgot. You have to pretend you're just one of the guys on these forums.
Huh?
I don't understand what you are trying to imply.
Maybe you can elaborate?
22. Re: How to create Black aspect ratio bars like in Final Cut Pro.
JSS1138 Jul 29, 2013 9:04 PM (in response to joe bloe premiere).But to 'emulate' that look by chopping off the top and bottom of 1080 video seems sorta faddish and semi-pointless.
Cameron agreed when he shot Avatar in 16:9.
I still like the wider aspect, though. I'm old school.
23. Re: How to create Black aspect ratio bars like in Final Cut Pro.
JaysonM-Y Jul 29, 2013 9:24 PM (in response to JSS1138) -
24. Re: How to create Black aspect ratio bars like in Final Cut Pro.
shooternz Jul 29, 2013 9:54 PM (in response to JaysonM-Y)That image is demonstrates what I hate about faux aspect ratio manipulation.
Great image as clean.. crap with the distracting black bars.
Is he peering into a letterbox?
25. Re: How to create Black aspect ratio bars like in Final Cut Pro.
But since all consumer displays are 16:9, how else is anyone going to view 2:39:1 material , whether faux or "real", without "distracting black bars"? The same objection could have been raised to letter-boxed 1:85 material, when most TVs were 4:3.
26. Re: How to create Black aspect ratio bars like in Final Cut Pro.
JSS1138 Jul 30, 2013 8:56 AM (in response to shooternz)faux aspect ratio manipulation.
If that's Clint, it ain't faux. Sergio wanted that precise framing. Letterbox is the only way to watch it correctly on a TV.
28. Re: How to create Black aspect ratio bars like in Final Cut Pro.
shooternz Jul 30, 2013 1:52 PM (in response to JSS1138)If that's Clint, it ain't faux. Sergio wanted that precise framing. Letterbox is the only way to watch it correctly on a TV.
Sure but keep in mind it wasnt shot with TV as the primary presentation method.
It was originally seen "clean" (sans bars) at the cinema as Sergio intended.
29. Re: How to create Black aspect ratio bars like in Final Cut Pro.
JSS1138 Jul 30, 2013 1:57 PM (in response to shooternz)You're right. And that's why I think we need a new worldwide television standard - CinemaTV™
2400 x 1000; 10 bit; 24 or 48 fps exact (no interlacing) with 96HZ playback.
That way the black bars go back on the sides, where they belong.
