0 Replies Latest reply: Jul 29, 2013 6:56 AM by robirdman1 RSS
    What is wrong with CS6 crop?
    robirdman1 Community Member
      I can't understand why they removed the 3rd box for resolution that they had before, after width and height.
      It seems to have screwed up the way crop works.  sometimes, I type in numbers such as 12 x 9 inches and some other crop happens.
      I had created a crop that was 1024 points by 672 points and resolution 72.  I saved it under the suggested name.
      Later it was determined that I needed 1024x672  with resolution 96 instead.
      I did a trial crop and I could see that the size resulting of over 12x9 inches was too large.
      I go to the images size menu and see that its says 1365 x 865 points at resolution 96. If I change the resolution to 72, after first checking resample, THEN the top reads 1024x672 points.  and the file size is 1.97meg, which it is supposed to be instead of 3.5 as it said before.
      So it is still cropping as 1024 x 672 x 72, but showing it as 1365x 865 x 96.
      I deleted both saved crops and made a new one.  No difference.  I restarted CS6 and tried again.  No matter what, it won't allow this new crop with the correct parameters.  Cropping used to be so simple till they "improved" the function.
