I am trying to upgrade an existing system from CF 8 to CF 10. I have a datasource that connects to a Unidata database. The datasource connects on the CF 8 server using driver class com.ibm.u2.jdbc.UniJDBCDriver and driver uniJDBC. I set the datasource up on CF 10 the same way it is set up on CF 8. I copied over the unijdbc.jar and asjava.zip files from /opt/coldfusion8/wwwroot/WEB-INF/classes on the old server and put them in /opt/coldfusion10/cfusion/wwwroot/WEB-INF/classes on the new server. I updated the Coldfusion Class Path to
/opt/coldfusion10/cfusion/wwwroot/WEB-INF/classes/unijdbc.jar,/opt/coldfusion10/cfusion/wwwroot/WEB-INF/classes/asjava.zip,"%CLASSPATH%"
on the Java & JVM settings page in the CF 10 Administrator and restarted coldfusion before I tried adding the datasource. When I try to verify the datasource I get this error:
Connection verification failed for data source: colleague
java.lang.AbstractMethodError: com.ibm.u2.jdbc.UniJDBCDatabaseMetaData.getJDBCMajorVersion()I
The root cause was that: java.lang.AbstractMethodError: com.ibm.u2.jdbc.UniJDBCDatabaseMetaData.getJDBCMajorVersion()I
The database I am connecting to has not changed, it is still the same version and in the same location. What exactly does this error mean? Would I need updated versions of the unijdbc.jar and asjava.zip files to go with CF 10, even though the database has not changed?
Thanks in advance for any help,
Julie
When I try to verify the datasource, I get this error stack in the exception.log file, perhaps this means something to someone? thanks...
"Error","ajp-bio-8012-exec-30","07/15/13","10:21:46",,""
at coldfusion.server.j2ee.sql.JRunConnection.<init>(JRunConnection.java:133)
at coldfusion.server.j2ee.sql.pool.JDBCPool.create(JDBCPool.java:555)
at coldfusion.server.j2ee.sql.pool.JDBCPool._checkOut(JDBCPool.java:472)
at coldfusion.server.j2ee.sql.pool.JDBCPool.checkOut(JDBCPool.java:378)
at coldfusion.server.j2ee.sql.pool.JDBCPool.requestConnection(JDBCPool.java:825)
at coldfusion.server.j2ee.sql.pool.JDBCManager.requestConnection(JDBCManager.java:125)
at coldfusion.server.j2ee.sql.JRunDataSource.getConnection(JRunDataSource.java:135)
at coldfusion.sql.CFDataSource.getConnection(CFDataSource.java:42)
at coldfusion.sql.Executive.verifyDatasource(Executive.java:492)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at coldfusion.runtime.StructBean.invoke(StructBean.java:508)
at coldfusion.runtime.CfJspPage._invoke(CfJspPage.java:2465)
at cfudflibrary2ecfm1867463752$funcVERIFYDSN.runFunction(E:\cf10_final\cfusion\wwwroot\CFIDE\administrator\datasources\udflibrary.cfm:14)
at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:472)
at coldfusion.runtime.UDFMethod$ArgumentCollectionFilter.invoke(UDFMethod.java:368)
at coldfusion.filter.FunctionAccessFilter.invoke(FunctionAccessFilter.java:55)
at coldfusion.runtime.UDFMethod.runFilterChain(UDFMethod.java:321)
at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:518)
at coldfusion.runtime.CfJspPage._invokeUDF(CfJspPage.java:2624)
at cfindex2ecfm782328217._factor12(E:\cf10_final\cfusion\wwwroot\CFIDE\administrator\datasources\index.cfm:450)
at cfindex2ecfm782328217._factor17(E:\cf10_final\cfusion\wwwroot\CFIDE\administrator\datasources\index.cfm:396)
at cfindex2ecfm782328217._factor18(E:\cf10_final\cfusion\wwwroot\CFIDE\administrator\datasources\index.cfm:168)
at cfindex2ecfm782328217.runPage(E:\cf10_final\cfusion\wwwroot\CFIDE\administrator\datasources\index.cfm:1)
at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:244)
at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:444)
at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
at coldfusion.filter.IpFilter.invoke(IpFilter.java:64)
at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:443)
at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:48)
at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40)
at coldfusion.filter.PathFilter.invoke(PathFilter.java:112)
at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:94)
at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28)
at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46)
at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at coldfusion.filter.CachingFilter.invoke(CachingFilter.java:62)
at coldfusion.filter.RequestThrottleFilter.invoke(RequestThrottleFilter.java:151)
at coldfusion.CfmServlet.service(CfmServlet.java:204)
at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42)
at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at coldfusion.filter.ClickjackingProtectionFilter.doFilter(ClickjackingProtectionFilter.java:75)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:224)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:169)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:928)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:414)
at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:203)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:539)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:298)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Can you please copy this jar file to this location and try again.
,/opt/col dfusion10/cfusion/runtime/lib/
restart the service and try to create the connection again.
Priyank
Hello,
thank you very much for your suggestion. I did try it, but still get this same error when try to verify the datasource:
and the following is seen in the /opt/coldfusion10/cfusion/logs/exception.log:
"Error","ajp-bio-8012-exec-3","07/16/13","14:56:00",,"com.ibm.u2.jdbc.UniJDBCDatabaseMetaData.getJDBCMajorVersion()I"
I have just found out from the vendor that the JDBC driver for unidata has a known issue and will not work with CF 10 and some other servers. I will be attempting an ODBC connection instead.
Hello,
Thank you for the update.
Anit Kumar
