6 Replies Latest reply: Aug 1, 2013 6:20 AM by khkremer RSS
    Adobe Acrobat XI crashes on Closing files
    WaseemK124 Community Member
      We are facing issue with Acrobat XI professional :
      When closing file on :
      1) Windows 7 Enterprise 32 bit machine Acrobat is crashing and we are getting following error in event log :
      Faulting application name: Acrobat.exe, version: 11.0.0.379, time stamp: 0x505fd1ce
      Faulting module name: BIB.dll, version: 1.2.2.1, time stamp: 0x505fd1e5
      Exception code: 0xc0000005
      Fault offset: 0x00002d4b
      Faulting process id: 0x25c8
      Faulting application start time: 0x01ce8d055ae6dd84
      Faulting application path: C:\Program Files\Adobe\Acrobat 11.0\Acrobat\Acrobat.exe
      Faulting module path: C:\Program Files\Adobe\Acrobat 11.0\Acrobat\BIB.dll
      Report Id: a8a6b7db-f8f8-11e2-8b05-005056c00008
      2)  Windows 7 Enterprise 64 bit machine Acrobat is crashing and we are getting following error in event log :
      Faulting module name: Acrobat.dll, version: 11.0.0.379, time stamp: 0x505fd1b6
      Fault offset: 0x0003c672
      Faulting process id: 0x1700
      Faulting application start time: 0x01ce8d0c8d2d4049
      Faulting application path: C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\Acrobat.exe
      Faulting module path: C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\Acrobat.dll
      Report Id: 094e5077-f900-11e2-befb-000c298aec38
      We also tried after intalling Acrobat update (11.0.3) but still facing same issue.
      Addition to this : We have Custom plug-in for Adobe Acrobat. This plug-in is compiled and build without ADM library.
      As per this post we donot require ADM libraries anymore : http://forums.adobe.com/thread/1082976
      Following is the DEBUG LOG when debugging the plug-in code :
      The thread 'Win32 Thread' (0x2284) has exited with code 0 (0x0).
      'Acrobat.exe': Unloaded 'C:\Program Files\Adobe\Acrobat 11.0\Acrobat\AXE8SharedExpat.dll'
      The thread 'Win32 Thread' (0xcb4) has exited with code 0 (0x0).
      The thread 'Win32 Thread' (0x2598) has exited with code 0 (0x0).
      'Acrobat.exe': Unloaded 'C:\Program Files\Adobe\Acrobat 11.0\Acrobat\Acrobat.dll'
      'Acrobat.exe': Unloaded 'C:\Program Files\Adobe\Acrobat 11.0\Acrobat\CoolType.dll'
      'Acrobat.exe': Unloaded 'C:\Program Files\Adobe\Acrobat 11.0\Acrobat\AGM.dll'
      The thread 'Win32 Thread' (0xdd0) has exited with code 1 (0x1).
      The thread 'Win32 Thread' (0x1d0c) has exited with code 1 (0x1).
      The thread 'Win32 Thread' (0xf04) has exited with code 1 (0x1).
      The thread 'Win32 Thread' (0x13d0) has exited with code 1 (0x1).
      The thread 'Win32 Thread' (0x1fd0) has exited with code 1 (0x1).
      The thread 'Win32 Thread' (0x1058) has exited with code 1 (0x1).
      The thread 'Win32 Thread' (0x198c) has exited with code 1 (0x1).
      The thread 'Win32 Thread' (0x974) has exited with code 1 (0x1).
      The thread 'Win32 Thread' (0x201c) has exited with code 1 (0x1).
      The thread 'Win32 Thread' (0x220c) has exited with code 1 (0x1).
      The thread 'Win32 Thread' (0x26e8) has exited with code 1 (0x1).
      The thread 'Win32 Thread' (0x26ec) has exited with code 1 (0x1).
      First-chance exception at 0x08d32d4b in Acrobat.exe: 0xC0000005: Access violation writing location 0x0d2d5edc.
      Unhandled exception at 0x08d32d4b in Acrobat.exe: 0xC0000005: Access violation writing location 0x0d2d5edc.
      The program '[4292] Acrobat.exe: Native' has exited with code -1073741819 (0xc0000005).
      I also came across a post where they mention to run Acrobat as Vista / Windows 7 Compatibility mode.  :http://forums.adobe.com/thread/792700
      Thanks in Advance.
        • 1. Re: Adobe Acrobat XI crashes on Closing files
          Test Screen Name CommunityMVP
          The problem goes away if the plug-in is removed?
          • 2. Re: Adobe Acrobat XI crashes on Closing files
            khkremer CommunityMVP
            You say you have a custom plug-in - is this something you created, or a
            plug-in that somebody else created for you? If you wrote the plug-in, you
            need to run Acrobat in the debugger and see where it crashes. If you are
            not the author, you have to work with the developer to debug the problem.
            Make sure that you release any resource you've acquired. Are you doing
            anything in an "OnClose" callback? If so, check that code carefully (but
            again, running Acrobat in the debugger should point you to where things go
            wrong).
            Karl Heinz Kremer
            PDF Acrobatics Without a Net
            PDF Software Development, Training and More...
            khk@khk.net
            http://www.khkonsulting.com
            • 3. Re: Adobe Acrobat XI crashes on Closing files
              Yes. Problem goes away when plug-in is not there.
              I tried to run Acrobat XI with Windows 7 Compatibility mode and it worked but this is not a solution which i am looking for.
              Sometimes Acrobat crash after uninstallation of plug-in as well.
              Addtion to it: It works fine with Adobe Acrobat X.
              • 4. Re: Adobe Acrobat XI crashes on Closing files
                Hi Karl, Thanks for Reply.
                I have created the custom plug-in. I run the Acrobat in debugger and tried to close a file opened using my custom plug-in. Acrobat closes the file and after clean up (i have a method MyUnload), i get following message in alert:
                "Unhandled exception at 0x05812d4b in Acrobat.exe: 0xC0000005: Access violation writing location 0x0dd25edc".
                Following is the callstack from debugging :
                >05812d4b()
                AdobePDFL.dll!0d262aec()
                [Frames below may be incorrect and/or missing, no symbols loaded for AdobePDFL.dll]
                AdobePDFL.dll!0ce11ab0()
                AdobePDFL.dll!0ce11b99()
                AdobePDFL.dll!0ce110c1()
                AdobePDFL.dll!0ce1121c()
                AdobePDFL.dll!0ce11287()
                ntdll.dll!773d8968()
                ntdll.dll!773de094()
                ntdll.dll!773df978()
                ntdll.dll!773dcca0()
                ntdll.dll!773e222b()
                msvcr100.dll!72ab7b1d()
                Acrobat.exe!00f5472b()
                kernel32.dll!76b4ed6c()
                ntdll.dll!773e377b()
                ntdll.dll!773e374e()
                The program '[2856] Acrobat.exe: Native' has exited with code -1073741819 (0xc0000005).
                It closes the file and crashes after it. Following is the screen i am getting when closing a file:
                But when set acrobat XI comatibility mode to Windows 7, it doesn't crashes.
                Let me know if you want more info reagrding this.
                Thanks you once again.
                • 5. Re: Adobe Acrobat XI crashes on Closing files
                  I believe you may already have had the best advice: Make sure that you release any resource you've acquired.  Acrobat seems to require more tidiness with each release.
                  • 6. Re: Adobe Acrobat XI crashes on Closing files
                    There is one more advice that's even more important: Use exception handling
                    (DURING/HANDLER blocks) around anything that can potentially throw an
                    exception.
                    Debugging these problems is one or the more challenging parts of working
                    with the plug-in API.
                    Karl Heinz Kremer
                    khk@khk.net
                    On Thu, Aug 1, 2013 at 4:36 AM, Test Screen Name
