Problem: Can't export apps to my Android device now that it was upgraded to Android 4.3
I just installed Android 4.3 and all the problems started. Everything was working great with 4.2.2.
Is this a know issue?
Also some of my previously installed Flex apps will not run on my 4.3 device. Some old apps do
run and this is very confusing as I have no clue why they all where created with Flash Builder 4.7 and Air 3.7.
I can't even build a simple Hello World mobile app. Is this a know issue?
My system:
Mac Flash Builder 4.7 with Air 3.7
I don't have an answer but have the same problem. A nexus which was upgraded no longer publishes from FB but I still have a 4.2.2 nexus which is ok. I suspect you have to download the 4.3 sdk and copy the build tools. There are posts around on having to set up FB with various build exes in the sdk
The AIR 3.7 build 3.7.0.153 had the known issue which was fixed in build 3.7.0.176.
I installed a newer version of Air 3.7 and now everything seems to be working fine with Android 4.3. Version 3.7.0.2100
Air 3.8 also solves the problem
