5 Replies Latest reply: Aug 2, 2013 7:42 AM by Szalam RSS
    Importing After effects sequences to premier pro with camera and effects
    Nikhita P. Community Member
      Hi there,
      I'm gonna try n put this across as best as I can. I have made a short film of 6 minutes (in 6 parts on after effects) I have added all the effects and the camera work on AE, but it needs a lot of editing here and there, which I find impossible to do on AE since you can't cut and join scenes like Premier pro. I need to import all these sequences onto premier pro for editing now. The problem is once I import the files, it imports in the right order in systematic folders etc, but it doesn't show any of the camera work or the special effects like gaussian blur etc. All my hard work has gone.
      There must be a way you can import the after effects file on premier the way it looks on AE. Can somebody please help me?
      Another problem is I read some boards and it has been suggested to edit the clips first on premier and then add effects on AE but I read this really late and I've already composited the whole film on AE. I just need premier for cutting now.
      Thanks for any help in advance.
      Cheers,
      Nikhita
      P.S: I also thought about exporting the AE sequences as TGA files but there's ZERO space left in my internal hard disk for that, and it would take forever to export them all anyway. Any other kind of export would reduce the original quality which I dont want, and which I dont have space for anyway, so that option is out as well.
        • 1. Re: Importing After effects sequences to premier pro with camera and effects
          Rick Gerard CommunityMVP
          The short answer is no. You are not understanding the differences between AE and Premiere.
          The normal workflow is to do your compositing in After Effects and then render to a production codec that is lossless or nearly lossless to maintain quality, then edit in Premiere or your favorite NLE.
          You can use dynamic link to open an AE project in Premiere Pro, but if the project is complex or uses any GPU accelerated effects in AE like 3D layer extrusion, then this is a bad idea.
          Zero space left on your drive is not an excuse. You should not be rendering or reading to the system drive unless you have no other option and with Terabyte drives less than $100 now, not having another drive, even attached to a laptop is just a waste of time. If you want to create shots in AE and edit them in Premiere Pro, the best option is to render.
          • 2. Re: Importing After effects sequences to premier pro with camera and effects
            Hi Rick,
            Thanks for the response.
            If I render in a lossless codec from AE and then edit it in premier, will the quality become even lesser?
            I'm not making excuses, and it is not about the cost. I have external drives, but I thought that you can't store on an external drive if you're working on the files. If I have to reuse them, won't I have to relink them individually?
            • 3. Re: Importing After effects sequences to premier pro with camera and effects
              Every production house in the world that is working on more than one project uses external storage for their video files. As long as the drive name and path do not change you have no problems.
              Lossless or nearly lossless means that. No visible reduction in quality. That's why every production house that knows what they are doing uses production codecs in their workflow. Production codecs range from uncompressed (which very few use) to Avid, Black Magic Design, ProRez and a host of other specialized codecs. Jpeg2000 and png QuickTime can store alpha channels as well as a bunch of other 3rd party codecs.
              The way you start loosing quality is to use highly compressed formats like H.264 or MPEG or AVCHD in your production pipeline. It is usually OK to start with these codecs as original footage if the camera you used only offers these options, but any use of a delivery format in the production pipeline for anything but delivery is not a good idea.
              • 4. Re: Importing After effects sequences to premier pro with camera and effects
                Hi Rick,
                Oh alright I wasn't aware of that. Thanks so much. I'll use an external drive and render the files in lossless.
                Thanks for taking the time to explain the production codecs to know, I know very little about this. I really appreciate it. Thanks.
                • 5. Re: Importing After effects sequences to premier pro with camera and effects
                  Szalam CommunityMVP
                  Another excellent codec to use is the Cineform codec (free!). It's nearly lossless and has quite small file sizes compared to Quicktime with the PNG codec. If space is an issue, I would recommend it. Another popular one is the DNxHD codec, but I found Cineform edges it out on quality of the footage in my tests.
