1. Re: How can I stop an audio?
Alex Kruger Aug 3, 2013 12:28 PM (in response to Eulalie87)You can see the buzz js library here: http://buzz.jaysalvat.com
The library have been very usefull for me,
Alex
2. Re: How can I stop an audio?
resdesign Aug 3, 2013 1:03 PM (in response to Alex Kruger)If you are using buzz, you can use stop(); to stop a sound.
I posted some info on this thread:
3. Re: How can I stop an audio?
Eulalie87 Aug 27, 2013 2:11 AM (in response to resdesign)Yes I try to use it but every time I come back on the homepage, The audio starts again. I can't find the solution.
4. Re: How can I stop an audio?
SEIF BH Aug 27, 2013 3:50 AM (in response to Eulalie87)EC.Sound.Stop("NameElement");
5. Re: How can I stop an audio?
Eulalie87 Aug 27, 2013 4:41 AM (in response to SEIF BH)It is not working. I must not write the code in the right place.
yepnope({nope:['buzz.js',],complete:init});
function init(){myfile=new buzz.sound("testpaul",{formats:["mp3","ogg","wav"],loop:'true'}) ;
myfile.play();
EC.Sound.Stop("testpaul");
6. Re: How can I stop an audio?
SEIF BH Aug 27, 2013 6:09 AM (in response to Eulalie87)if you need onther thing contact me
7. Re: How can I stop an audio?
Eulalie87 Aug 27, 2013 6:29 AM (in response to SEIF BH)Yes please!! I am lost. I try many things to stop the audio. But I can't find. Is it possible to launch only once an audio?
I write this code :
myfile.play();
The audio starts but I can't stop it when I come back to the homepage.
Please! help me! I am desperate
8. Re: How can I stop an audio?
SEIF BH Aug 27, 2013 6:52 AM (in response to Eulalie87)No work with this function :
try {
yepnope({
load: "http://simonwidjaja.github.com/EdgeCommons/live/EdgeCommons-0.6.0.js",
callback: function() {
// Load sound manifest (e.g. in creationComplete)
var assetsPath = "sounds/";
EC.Sound.setup(
{src: assetsPath + "est.mp3|" + assetsPath + "est.ogg", id: 'est'},
{src: assetsPath + "sound.mp3|" + assetsPath + "sound.ogg", id: 'sound'},
function(){ EC.info("Sound setup finished", "Sound with Edge Commons"); }
catch(error) {
console.error("sw", error);
c=1;
_________
and this is function to 1 button play and stop sound :
if ( c == 1 ){
EC.Sound.stop("namesound");
// play the timeline from the given position (ms or label)
c = 2 ;
else
EC.Sound.play("namesound");
c = 1
SEIF
9. Re: How can I stop an audio?
Eulalie87 Aug 27, 2013 7:03 AM (in response to SEIF BH)Should I paste all this code on the stage? Sorry I am really bad!!!
10. Re: How can I stop an audio?
SEIF BH Aug 27, 2013 7:07 AM (in response to Eulalie87)No probleme , No problem Create a folder in your file , and Renamet it 'Sounds' And past this ...
Past this in CreationCompete
___________________________
try {
yepnope({
EC.Sound.setup(
catch(error) {
c = 1;
and past this in CompostionReady :
i=0;
sym.$('btn').click(function(){
i++;
sym.play("p" + i);
sym.$('btnStop').click(function(){
EC.Sound.stop("est");
and this in action to picture sound or what you want ....
if ( c == 1 ){
sym.play("tr");
c = 2 ;
else
sym.play("tr1");
EC.Sound.play("est");
c = 1
11. Re: How can I stop an audio?
resdesign Aug 27, 2013 7:08 AM (in response to Eulalie87)Here is a sample:
12. Re: How can I stop an audio?
resdesign Aug 27, 2013 7:23 AM (in response to SEIF BH)You probably need to put your starting sound at the right place because if the timeline goes back to your play code it will start again.
13. Re: How can I stop an audio?
SEIF BH Aug 27, 2013 7:34 AM (in response to resdesign)this is helpful ?
14. Re: How can I stop an audio?
Eulalie87 Aug 27, 2013 7:48 AM (in response to SEIF BH)Yes. Thanks. I try out.
15. Re: How can I stop an audio?
SEIF BH Aug 27, 2013 7:49 AM (in response to Eulalie87)Put Yes in the down of page(if this helpful )
16. Re: How can I stop an audio?
Eulalie87 Aug 27, 2013 8:01 AM (in response to resdesign)I think so but I want the audio starts at the beginning. Can I do something without create a button stop?
17. Re: How can I stop an audio?
resdesign Aug 27, 2013 8:34 AM (in response to Eulalie87)You need to add a flag that will tell you where the playhead is and then set the flg to true or false.
If you want you can PM me your project and I will look at it.
18. Re: How can I stop an audio?
SEIF BH Aug 27, 2013 11:30 AM (in response to Eulalie87)yes this simple
make this in compositionready :
19. Re: How can I stop an audio?
resdesign Aug 28, 2013 8:57 AM (in response to resdesign)I think the only way you could do this is by using a session and have a flag so that when the user comes back to the page in that session, the sound does not play.
But let me play with it some more so I can see if this can be done directly in edge.
20. Re: How can I stop an audio?
resdesign Aug 28, 2013 9:52 AM (in response to Eulalie87)You need to use webstorage and then set it up so that it will store the conditions - if it has not played, allow autoplay and if it has already played once set the audio to autoplay false.
see webstorage doc here:
http://www.w3schools.com/html/html5_webstorage.asp
He audio would have to be placed in the html file not in Edge.
Marie
21. Re: How can I stop an audio?
heathrowe Aug 28, 2013 11:30 AM (in response to resdesign)This sessionStorage example may be a better fit:
/////////////////creationComplete////////////////////////
if(!window.sessionStorage || (window.sessionStorage && !window.sessionStorage.getItem("seenanimation"))) {
if(window.sessionStorage) window.sessionStorage.setItem("seenanimation",1);
} else {
Darrell
22. Re: How can I stop an audio?
resdesign Aug 28, 2013 11:35 AM (in response to heathrowe)Awesome Darrell! That's basically what I was aiming at. Your solution beats mine!!!
They are using buzz.js but they can do the same thing.
23. Re: How can I stop an audio?
heathrowe Aug 28, 2013 11:47 AM (in response to resdesign)No sweat,
I just grabbed one of the examples from previous thread - also just realized that the getitem reference will need to be adjusted accordingly.
D
