die ordnungszahl 459 wird in urlmount.dll nicht gefunden.
What is your operating system & version?
You get that error when doing what?
Hello,
i use Win7 32bit version
after download the " install_flashplayer11x32_mssd_aaa_aih.exe" then i execute this and 3seconds later i become the error massage !canaot find Ordnungszahl ??459 in "urlmount.dll"
i must two times press "ok" then close the errormessages window.
greetings Dieter Gohlke
Try using the offline installer(s) from http://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-windows.html#main-pars_hea...
Hello Pat,
yes this hint was exellent. and helpfully,
greetings from Germany
Dieter Gohlke
So the problem is resolved?
Gruss aus Japan!
Hello Pat, yes my problem is fixed. thanks .
Japan???
greeting from Ostfriesland where the peoples says " Moin" for every Daytime
Dieter Gohlke
