I've successfully added ecommerce tracking for Google Analytics to my Business Catalyst sites. I haven't found any [free] definitive guides out there, so I thought I'd share.
For the tracking script, the Business Catalyst file you need to have opened is /Layouts/OnlineShop/order_receipt-US.html.
However, you also need to add the Google analytics script - with out the ecommerce modification - to all the pages on your site. I recommend putting in the <head> of your page templates.
To start tracking Business Catalyst ecommerce transactions with Google Analytics, here are the steps you need to take.
script type="text/javascript" var _gaq = _gaq || []; _gaq.push(['_setAccount', 'UA-*******-*']); // your Google Analytics profile id _gaq.push(['_setDomainName', 'example.com']); // your domain name - not *.worldsecuresystems.com, but the domain you've chosen for your site _gaq.push(['_setAllowLinker', true]); _gaq.push(['_trackPageview']); _gaq.push(['_addTrans', "{tag_orderid}", // Order ID "", // Affiliation "{tag_amount}", // Total "", // Tax "", // Shipping "", // City "", // State "" // Country ]); _gaq.push(['_trackTrans']); (function() { var ga = document.createElement('script'); ga.type = 'text/javascript'; ga.async = true; ga.src = ('https:' == document.location.protocol ? 'https://' : 'http://') + 'stats.g.doubleclick.net/dc.js'; var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(ga, s); })(); /script
You won't see all the details about the purchase in Google Analytics. That's because Business Catalyst does not pass all the needed variables to the order receipt page. [Perhaps that's a feature request.]
However, it's still valuable to know the order ID and revenue in Google Analytics - knowing which sources drive your revenue is critical. It's also pretty easy to grab the order ID [under Ecommerce > Transactions in Google Analytics] and look in your Business Catalyst site for the order. Here's a screenshot of the results I saw on the first day.
Google Analytics could collect the following if Business Catalyst passed it to the order_receipt-US.html page.
These two articles should get Business Catalyst developers a long way toward enabling
...Copy link to clipboard
I love this article, J! Is it OK if a convert it to a document? Please post your site here so that I can link it on the bottom and give you a proper credit for it.
Thanks for sharing your knowledge with the community!
-m
Thanks. You can link to http://brockms.com/. But I'd want to make it a bit more thorough before you turn it into a document. Would that be something I send you in a message?
Yes. Please PM me once you're happy with it.
Cheers,
-mario
Justin, I'd like to get you a hand with this doco. I've got a few tips I can share.
For example if you put the {tag_amount} into a variable you can re-use it for things like event tracking.
Thanks Justin! You are a super star for sharing this. Just what I was looking for
Fantastic - Thanks for your efforts brockms - was doing my head in.
How/Where do I access/open this page:
You can either navigate in the BC backend:
Site Manager > Module Templates > Online Shop Layouts > Recipt - Buy
or through Dreamweaver
Root > Layouts > OnlineShop > order_receipt-US.html
Thank you!
Just wanted to check - I've only got the tracking code in the default template so do I paste the full code again in the Receipt-Buy section (even though it uses the default template) or is it ok to just at the below to the default template?
"", // Affiliation
"", // Tax
"", // Shipping
"", // City
"", // State
"" // Country
Sorry if a silly question
Justin, thanks a lot for sharing.
You mentioned That's because Business Catalyst does not pass all the needed variables to the order receipt page
Would you please list what else BC should make available in order to make it possible to produce the desired GA reports? We will look at adding those.
And what are the reports you're usually looking at in GA for your BC sites?
These two articles should get Business Catalyst developers a long way toward enabling this
It would be nice if this were a simple site setting option in the admin console. I built a WordPress store once, for instance, that only required my Google Analytics profile id (the 'UA-*******-*' number). Once I entered it, analytics worked site wide and transactions showed up, too.
In Google Analytics, I look at a number of reports. I'll use the reports under the Advertising tab to evaluate my return on ad spend. I also use the reports under the Conversions tab to work backwards from purchases and completed goals to sources or site changes that impacted them.
Thanks Justin.
We're aiming to make GA fully work with BC as easily as providing your profile id, and the information you provided here helps us in this direction.
That's wonderful! Thank you and let me know if I can help in any other way.
Marius,
What's missing is the transactional data for each product.
We have to do a massive cookie workaround to pass each of the products purchased across so we can get a complete picture of the order processed. Not just the total.
Like Justin said, you've got access to google's dev code so it's pretty self explanatory what we need.
DOESN'T WORK?? it stops tracking when it goes to the world secure systems. No listing of any pages when they go to that site. I double checked everything, the code is on all pages, and on the receipt page it should be correct.
BTW the code listed shows doubleclick.net versus google.com (but neither I think works).
This guide will help you get around the *.worldsecuresystem.com problem
- Jonathan from http://www.olct.co/
If anyone is interested with cross domain revenue tracking for products with BC's ecommerce module drop me a line. gary@itbusiness.com.au
Currently you can only track the complete order but I've developed a method to now also track individual products as well.
We would all like to know that, Gary.
Yeah .. I'm working on trying to standardise the process to make it easier to install as it's a bit more complicated than a cut and paste job; And if not installed correctly it will break the ordering process which is why I'm hesitant to write up a tutorial. But I'll definately look at putting up some notes on my website when I'm confident of a DIY install!
Awesome Post sir..my eCommerce tracking is working perfectly in the analytic..but why it is showing (direct) / (none) under SOURCE / MEDIUM in my Google Analytic Dashboard and also if you can let me know the exact Thanks Page after successful payment please.
Please See the screen shot :
Thanks !
You're showing (direct) / (none) under Source/Medium because the purchases that have been made so far came through direct traffic.
As other sources send you converting traffic, you'll see other Source/Medium combinations:
... and so on.
Here's Google's article on how to make sense of traffic sources: https://support.google.com/analytics/answer/1033173
But other sources are seen under BC Dashboard and not under Google Analytics..Any suggestions please?
I've noticed a discrepancy between the two analytics before, as well. I tend to trust Google Analytics more because I've had more experience with it. Plus, I'm pessimistic, and Google shows fewer visits. 🙂
But in terms of your specific stats, make sure your date range only includes the time Google Analytics has been installed. Then make sure the Business Catalyst report only includes sources that resulted in purchases. Other than that, I'd need to look over your shoulder with a screen sharing tool to be of any use.
