I performed a scan with an updated version of Malwarebytes Anti-Malware and it flagged the following file with a Backdoor.MSIL.P infection:
../ColdFusion10/uninstall/uninstaller.jar
Can someone confirm the same or is this a false positive detection?
I have the same problem. The only difference is the file path for mine was .../ColdFusion9/uninstall/uninstaller.jar.
Any thoughts from the forum would be appreciated. Is this a legitimate file?
The date on the uninstaller.jar file matches the date of most other originally installed files in the CF directory. I think this is a false positive.
Hi All,
We are looking into this and will update you as soon as possible. Also could you please share your scanned result with us at cf.install@adobe.com
Priyank
Priyank - An email has been sent to you with the subject "Malware Scan Results."
Thanks, Let us check this and will let you know.
Priyank
I have that file as well and it is showing up as a trojan... any updates yet on this?
Hi Larry,
Our security team verified it and found that this was a false positive detection however if you're concern feel free to send an email with this jar file and your scan report to psirt@adobe.com.
Priyank
I received the same alert, flagging two files, also using Malwarebytes:
Backdoor.MSIL.P
c:/coldfusion9/inbridge/uninstall/uninstaller.jar
c:/coldfusion9/uninstall/uninstaller.jar
