Locked
Unable to save data model when importing WSDL webservice
Aug 08, 2013 Aug 08, 2013
I get this error when trying to import a webservice.
The details says: "
An error occurred while attempting to resolve the existing model.
ERROR : property "poId" has already been declared in this scope, at
The wsdl describes many clases which, in the server side, extend from a common parent class that defines de poId property.
Apparently Flash Builder does not like that all theese clases have a property with the same name when importing the WSDL.
I've come to a very unconfortable solution where I save a copy of the wsdl, then edit each apearance of the property with a different name (poId1, poId2, ...), and then I can successfully import the edited xml into flash. After this, I rename the properties with the intended original name, and there is no problem.
Maybe there is a workaround for not having to manually rename the properties each time i have to update the webservice.
Also:
- It would be nice to be able to import the wsdl into a Library project, since webservices may be consumed from more than one project.
- Sometimes after deleting ALL the generated source files for the webservice, and trying to import it again, Flash Builder refuses saying that already exists a webservice with that name, altough I have deleted the files like I said.
417
