Learn about Edge Delivery Services in upcoming GEM session
Reading Order Changed
Avatar
Former Community Member
I'm using LiveCycle Designer ES to create a form.  I made sure to set the reading order the way I wanted, but when I open the form in Acrobat Pro 9, the reading order is all off.  Can anyone explain why or how to fix?
Avatar
Hello,
You can set the reading order by changing the tabbing order while designing the form in LC designer. After changing the tabbing order, you need to save the XDP.
When you render the XDP(form) and open in Acrobat you can see the tagging in laft pannel.
If you open adn try to read the from it will read in order which you have set while designing the form.
If it is not working for you please share your form.
-Vijay
Avatar
Vijay:
I don't know what a XDP is. I created the form in LC and the tabbing order is just as I want it. I opened it as a PDF and the tab order is different.
If you can explain, I'd appreciate it!
Janet
Avatar
Please share the form, I need to look into that.
Avatar
I'm having trouble. I'm not able to reply to the forum even after logging in.
Avatar
We can see your reply, just attach the form while replying.
