I am using CF10 and Solr search, sometimes teh context has no values and makes it difficult to explain why a result ranks so high.
I found this
which explains how to make the necessary changes.
However, there is no 'conf' directory in my C:\ColdFusion10\cfusion\collections directory
Should I be updating in C:\ColdFusion10\cfusion\jetty\solr\conf ?
Some other location?
I need this to be a general fix applied to all current and future collections
Regarding the first one, yes it is correct. Yes it is easier ,if you are ready to create from scratch
Please mark this post correct, if it answers your query
VJ
Hi
solrconfig.xml location : C:\ColdFusion10\cfusion\verity\collections\collectionname\conf
schema.xml location : C:\ColdFusion10\cfusion\jetty\multicore\template\conf
VJ
Just to confirm, i need to update the existing collections individually but updating the file in Multicore will apply to new collections.
Is this correct?
Would it be easier/cleaner to update the multicore, delete the existing collections and rebuild from scratch?
VJ
updated multicore and recreated the collections
thanks
Much appreciated
