After created the MSI using AAMEE 3.1, the smi runs but then auto rolls back.
Windows 7 x64 SP1
Logs:
MSI:
MSI (s) (C8:14) [18:29:41:458]: Error in rollback skipped. Return: 5
Property(C): ErrorDialog = SetupError
MSI (c) (48:88) [18:29:42:458]: Product: Adobe Photoshop CS6 x86 -- Installation operation failed.
MSI (c) (48:88) [18:29:42:458]: Windows Installer installed the product. Product Name: Adobe Photoshop CS6 x86. Product Version: 1.2.0000. Product Language: 1033. Manufacturer: Adobe Systems Incorporated. Installation success or error status: 1603.
PDApp:
8/6/2013 18:20:38 [ERROR] Setup - Error parsing command line arguments at - "DISABLE_CCM_DESKTOPSHORTCUT".
8/6/2013 18:22:18 [ERROR] PIM - Failed to create Backup folder :5
8/6/2013 18:22:18 [FATAL] Setup - Error installing C:\Users\vmTester\Desktop\Adobe Photoshop CS6 x86\Adobe Photoshop CS6 x86\Build\Patches\AdobeApplicationManager-1.0_update7\packages\CCM\CCM.pimx package.
8/6/2013 18:22:18 [FATAL] Setup - Error in pim_InstallPackages returned -5
8/6/2013 18:24:03 [ERROR] LWANative - OOBElib returned error: 47
8/6/2013 18:24:03 [ERROR] LWANative - OOBElib returned error: 34
8/6/2013 18:24:04 [ERROR] DWANative - Error in dwa_getInstalledPathOfPayload, pdbSession is NULL.
8/6/2013 18:25:07.784 [INFO] P6Flex.ValidateSerialStatusCommand Received validate serial response : ERROR_SN_VALID
Hi STLCOP_IT,
Please check for Windows Installer is set to manual and started. Navigate to start/run/Services.msc/Select Windows Installer and check it should be set to manual and services status should be started. If this does not work perform selective startup and try installing again: http://windows.microsoft.com/en-in/windows-vista/run-selective-startup-using-system-configuration.
Try installing from hidden admin: http://www.howtogeek.com/howto/windows-vista/enable-the-hidden-administrator-account-on-windows-vist...
If still the same issue then kindly download Photoshop from the mentioned link: http://prodesigntools.com/adobe-cs6-direct-download-links.html . Create package again using AAMEE 3.1 and try to install.
kindly let me no how it worked.
Romit Sinha
I downloaded Photoshop from the link you provided and the MSI still auto rolls back.
I also tried starting the installer service (it was set to manual) to the same avail. The hidden admin account was also used.
Hi STLCOP_IT,
Please check for CC desktop at the taskbar. If it is running close it and try installing again. Please specify the command your are using to install. Run the command prompt in elevated mode and try to install again.
Romit Sinha
CC desktop isnt running. I am using msiname.msi /quiet obviously from an elevated cmd prompt. Is there an email address I cans end the full logs to?
I run the MSI just on any desktop and it auto rolls back.
Rolling back issue fixed.
1. If your package contains Acrobat, First run the exceptions Deployer application present in Exceptions folder in pre mode. If you don’t have acrobat in your package, you can skip this step.
Open CMD as administrator. locate the exceptions folder. "cd C:\CS6_MC_Windows_x32\Exceptions". Now, run this command: ExceptionDeployer.exe --workflow=install --mode=pre
2. Deploy the main MSI.
Open CMD as administrator. locate the Build folder. "cd C:\CS6_MC_Windows_x32\Build". Now run this command: Msiexec.exe /I <path of MSI> /qn for silent install or just msiexec.exe /I <path of MSI>
3. Run the exception deployer application again in post mode. This wil install remaining exceptions.
Open CMD as administrator. locate the exceptions folder. "cd C:\CS6_MC_Windows_x32\Exceptions". Now, run this command: ExceptionDeployer.exe --workflow=install --mode=post
No Acrobat, just Photoshop CS6 - this fix did not help.
hi,
Go to %Programfiles%/common files/Adobe/OOBE/PDApp. Rename/delete this folder (kep up a back up copy with you just in case) and then re try installing the package on the machine. This should work.
Saransh katariya | Adobe Systems | skatariy@adobe.com
Hello,
I am having exacly the same issue with Captivate 6. It is the same error. Has anyone figured out why it does happen.
I have packaged the product with AAMEE 3.1
I have used local admin accound still could not get to work.
Thanks for the efforts
I have the exact same issue no matter if I try a serilized package or a trial package using AAMEE 3.1. I tried creating the packages on 3 clean, fresh imaged machines.
Reviewing the logs
MSIf7e70.log:
Windows Installer installed the product. Product Name: Photoshop-CS6l. Product Version: 1.2.0000. Product Language: 1033. Manufacturer: Adobe Systems Incorporated. Installation success or error status: 1603.
MSI rolls back.
Please mail your PDApp.log file from user specific temp location (%temp%).
saransh katariya | Adobe Systems | skatariy@adobe.com
Hello,
Please see attached.
Kind Regards
Peter Burns, MA
Client Systems Engineer
St. Louis College of Pharmacy
4588 Parkview Place, St. Louis, Mo 63110-1088
TEL: 314.446.8412
FAX: 314-446-8400
EMAIL: Peter.Burns@stlcop.edu<mailto:Peter.Burns@stlcop.edu
It seems to happen only if you use AAMEE 3.1 to create a x86 (32bit) package. x64 msi packages seem to work fine. can somebody confirm this?
EDIT:
Another discovery that I have made:
All Installers work, if you run the msi installer from its context menu with "check compatibilty". This will cause skipping the version check and the programs (64 and 32bit) seem to install fine. (I assume that the version check of the operating system is skipped, but I'm not sure about that.)
I would be glad if some can confirm this, so maybe the guys at adobe can fix this, so that the installers work by default.
EDIT2:
I tested the "check compatibilty" installation on some other systems, but unfortunately this did not work. 😞
Adobe, please respond and fix this issue!
I've created a batch script which can be run as administrator. There I have the most successfull installations:
install.bat:
pushd %~dp0
Msiexec.exe /I "Adobe Photoshop CS6 x64.msi"
Just save this batch file in the folder where the generated msi package is, rightclick the batch and click "run as administrator". The "pushd %~dp0" line takes care that the script goes back to the directory where the batch and msi file is, the default for an elevated command promt is "C:\windows\system32", but there it wont find the installer there.
I would appreciate any response to this from Adobe!
