, today I tried to autorise for Adobe digital editions 2.0. Each time I fill in e-mail and password en push continu, I get a message (translated from Dutch) :Fault activatingserver; Code E-AUTH_NOT_READY; Digital Editions has detected a fault at the activatingserver; Try again.... I have tried for more then 10 times and each time it gives the same result. What to do??
Hi tsinahpah1,
1) Open Adobe Digital Editions if it is not already open. Select the Library view. Hold down Ctrl+Shift D and DE authorize your computer. When finished, Adobe Digital Editions will close.
2) Reopen Adobe Digital Editions and run through the setup assistant and enter the correct Adobe ID and password that you just changed.
Note: This problem is caused due to wrong Adobe ID registration due to which user is unable to download e book. So to check the id and activate it follow the mentioned steps:
Please refer the mentioned thread: http://forums.adobe.com/message/5310386 for similar issue.
Romit Sinha
