In After Effects CC anyone else notice as inside the graph editor some tangent handles are not showing up? I believe I noticed this on a position keyframe. I used F9 to easy ease the keyframe, went into the graph editor with the keyframe selected and did not see any handles I could adjust for timing. Any ideas? Bug?
There is no bug. The graphs default to spatial ever since CS6, which in case of position have no handles unless you split the XYZ. In older versions the graphs defaulted to the temporal interpolation and always showed handles.
Mylenium
Thanks Mylenium!
Click the box beside the eye symbol, then select Edit Speed Graph as seen in the pic above. There you can edit the easing with the little handles.
Thank you so much, I had been struggling with this problem for Ages!!!!
I love you!
tysm...worked for me :3
Thnkuuuu
