Is there a way to change the text size of the size panel, I'm talking about Diapo 1 - Diapo 2 Diapo 3... I can change the size of everything else except that...
Plus, does anyone know how to change the color of the slide heading ? I can't read it with my color background...
Caroline
Hi Caroline,
I dont understand the first problem clearly. What do you mean by Diapo 1-2-3
For the second issue, you may change the color of slide heading. follow the steps below:
1. Goto Themes under Presenter tab.
2. Under Appearance, change the font color.
Hope this help.
Alpi
Sorry, I speak french so I may not explain myself well...
The text size that I want to change is the slide name on the right, you know where you have Slide 1 0:05 - Slide 2 0:05 - Slide 3 0:05 and the color that I want to change is just above that, I can't change it in appearance...
Thanks !
Sorry, but currently there is no way you can change the color of the text 'Slide Title' and 'Duration'.
Alpi Agarwal
Adobe Presenter Engineering Team
Thanks you for your quick reply !
Do you know if I can change the text size of the slide name on the right ? I used to be able to do that in Presenter 7 but it doesn't seems to work in Presenter 9...
Thanks !
Caroline
I tried to change this line : <uifont name="FONT_OUTLINE" value="Verdana,14,false,false,true"/> in the <fr> section but it does nothing, it used to work witn Presenter 7,,,
