How can i get the attachment files from a email?
I'm using the following code:
<CFPOP ACTION="GETALL"
NAME="Message"
MESSAGENUMBER="#URL.idMsg#"
SERVER="server.mail.test"
USERNAME="test"
PASSWORD="teste"
ATTACHMENTPATH="f:\temp\email\">
But all the times i got the file f:\temp\email\winmail.dat.
How can i get the attachment file like pdf, xml and other?
Thank's
See the example in the docs.
http://livedocs.adobe.com/coldfusion/8/htmldocs/help.html?content=Tags_p-q_08.html
There is no exemple that save the attachment. Do you have one exemple to send?
If you read through it, there is a link to retrieve emails and save attachments.
http://livedocs.adobe.com/coldfusion/8/htmldocs/email_10.html#1096313
Thank you for your help.
I really read the full text, but all i got is a winmail.dat file.
If i use the generateUniqueFilenames i got file like winmail.dat, winmail1.dat, winmail2.dat, winmail3.dat
How can i extract the attachment file from winmail.dat?
Have you made a script that downloads the real attachment using pop?
Can you help?
Thank!
I tested with CF9 on Win7. It worked fine. Here's the code:
<cfpop server="mail.server.com" username="myemail@server.com" password="mypassword" action="getAll" name="my_pop3" startrow="1" maxrows="1" attachmentpath="C:\files\">
<cfdump var="#my_pop3#" />
The attachment was downloaded and stored in C:\files\.
Not sure why you got .dat file. I sent a PDF; and I received a PDF.
