1. Re: How to export Premiere Pro CC projects to Encore
John T Smith Jun 28, 2013 8:32 AM (in response to EDeetor1)Dynamic Link from PProCC to EncoreCS6 does not work
http://helpx.adobe.com/encore/kb/encore-cs6-installed-cc.html
2. Re: How to export Premiere Pro CC projects to Encore
Stan Jones Jun 28, 2013 8:56 AM (in response to EDeetor1)You can work with the export settings. You can get good quality out of direct exports.
I have not done it, but requests for an option in PR CC to do a "save as CS6" resulted in the recommendation to use the export as XML (or some such). I think this is used to get projects into FCP.
So try that as a way to get your PR CC project into PR CS6.
Or like some of us, just stick with CS6 and use dynamic link.
3. Re: How to export Premiere Pro CC projects to Encore
ThePetal Aug 12, 2013 5:57 PM (in response to Stan Jones)Hi Stan,
Unfortunately, CS6 no longer seems to be an option for downloading from the Adobe Creative Suite.
So I am reluctant, now, to recommend Premiere Pro to some of my clients who want to be able to create DVDs and Blu-Ray discs.
At least until Encore is available as a separate download, which I had initially thought was going to be the case. Apparently I was wrong.
4. Re: How to export Premiere Pro CC projects to Encore
John T Smith Aug 12, 2013 6:10 PM (in response to ThePetal)If you click the links I provided in #1 I think the process is described
You do not download/install Encore separately... you do PProCS6 and Encore is included... then there is supposed to be a way to uninstall only PProCS6 while keeping EncoreCS6
5. Re: How to export Premiere Pro CC projects to Encore
ThePetal Aug 14, 2013 12:05 AM (in response to John T Smith)Thank you for that John. I have everything working the way I want now and will pass on this link to others. Very good video tutorial.
