3 Replies Latest reply on Aug 12, 2013 6:33 PM by Lazlo Hollyfeld
    Using the socket object to retrieve data from web app without html files
    Sebastien Lavoie Level 1
      I tried using the socket object to retrieve data from a web app (I just check for script version vs current version online). So all I want to do is access http://hyle.io/version which returns me the current version of the app (as a simple string) so I can compare it in my script and then notify the user accordingly. I just have some problems using the socket object. I used this code from the Adobe Javascript Tools Guide :
      reply = "";
      conn = new Socket;
      // access Adobe’s home page
      if (conn.open ("www.adobe.com:80")) {
      // send a HTTP GET request
      conn.write ("GET /index.html HTTP/1.0\n\n");
      // and read the server’s reply
      reply = conn.read(999999);
      conn.close();
      ... which I then adapted as:
      reply = "";
      conn = new Socket;
      if (conn.open ("hyle.io:80")) {
        conn.write ("GET /version HTTP/1.0\n\n");
        conn.close();
      And here's what I receive:
      HTTP/1.1 400 Bad Request
      Content-Length: 225
      Content-Type: text/html
      Server: Pagodabox-Routing-Mesh
      Bad Request
      Your browser sent a request that this server could not understand.
      Résultat : true
      I don't know much about HTTP requests, but I was wondering if it was related to the fact that I am not pointing to a specific HTML file and the request type was then not okay or if I should instead check if there's something wrong with my host?
      The site/app is PHP and is hosted on PagodaBox if this can help.
      Thanks in advance!
        • 1. Re: Using the socket object to retrieve data from web app without html files
          Zhiqiang_Li Level 1
          Hi Sebastien Lavoie,
          This should work
          var HTTPFile = function (url,port) {
                    if (arguments.length == 1) {
                              url = arguments[0];
                              port = 80;
                    this.url = url;
                    this.port = port;
                    this.httpPrefix = this.url.match(/http:\/\//);
                    this.domain = this.httpPrefix == null ? this.url.split("/")[0]+":"+this.port :this.url.split("/")[2]+":"+this.port;
                    this.call = "GET "+ (this.httpPrefix == null ? "http://"+this.url : this.url)+" HTTP/1.0\r\nHost:" +(this.httpPrefix == null ? this.url.split("/")[0] :this.url.split("/")[2])+"\r\nConnection: close\r\n\r\n";
                    this.reply = new String();
                    this.conn = new Socket();
                    this.conn.encoding = "binary";
                    HTTPFile.prototype.getFile = function(f) {
                              var typeMatch = this.url.match(/(\.)(\w{3,4}\b)/g);
                              if (this.conn.open(this.domain,"binary")) {
                                        this.conn.write(this.call);
                                        this.reply = this.conn.read(9999999999);
                                        this.conn.close();
                              } else {
                                        this.reply = "";
                              return this.reply.substr(this.reply.indexOf("\r\n\r\n")+4);;
          var hyle = new HTTPFile("http://hyle.io/version");
          alert(hyle.getFile());
          And by the way, I like the idea of "http://hyle.io". Can you give me your email, I want to know more about this website.
          Please send me a email at 635366848@qq.com
          • 2. Re: Using the socket object to retrieve data from web app without html files
            Thanks, this is exactly what I was searching for!
            • 3. Re: Using the socket object to retrieve data from web app without html files
              Lazlo Hollyfeld Level 1
              Hey Sebastien,
              You should take a look into Extendables which is a framework for easily created HTTP requests with Extendscript.  The framework was built with InDesign in mind, but it works with AE.
              https://github.com/percentcer/Extendables
              Check out examples, and documentation on creating http requests.
              Best!
