1. Re: Photoshop CC Properties Panel Live Shape bug
SG... Aug 13, 2013 4:21 PM (in response to becca_s)Hi,
I moved this over to Photoshop General, because it is not a Creative Cloud problem, per se. This is a new feature of the Photoshop program branded as Photoshop CC (ver. 14.0). You will get more help and attention here, then posting it in the Creative Cloud forums.
The Creative Cloud forums will capture questions and issues around using the creative.adobe.com portal, application downloading, file syncing with your Creactive Cloud account, web services, etc.
regards,
steve
2. Re: Photoshop CC Properties Panel Live Shape bug
SG... Aug 13, 2013 4:33 PM (in response to SG...)Hi,
I'm asking the team about this behavior. Are you targeting the shape layer via the Layer panel and expecting to see the Live Shape properties?
regards,
steve
3. Re: Photoshop CC Properties Panel Live Shape bug
becca_s Aug 13, 2013 4:38 PM (in response to SG...)I've tried a bunch of things. Here, for example, In the layers panel, within a group, if I select one of the objects (either by clicking on it in the canvas or by selecting the layer) the properties panel shows me all of the options for the live shape and the option to toggle between live shape options and mask options. Then I immediately go to edit another shape (accessing it the same way, either through clicking on it in the canvas or by selecting the layer) and it only gives me mask options, but not the option to adjust the shape. I don't understand why this happens. I created both shapes with the U tool.
4. Re: Photoshop CC Properties Panel Live Shape bug
SG... Aug 13, 2013 4:59 PM (in response to becca_s)Hi,
It ends up being a design decision, based on limitations around multi-layer selection and multi-path selection. There were serious problems activating the Live Shape properties without making a deliberate gesture from users a requirement. That's why we only enable them when paths are targeted with the Path tool or Direct select tool.
regards,
steve
5. Re: Photoshop CC Properties Panel Live Shape bug
becca_s Aug 13, 2013 5:00 PM (in response to SG...)so how do I get it to show me those properties every single time instead of only arbitrarily?
6. Re: Photoshop CC Properties Panel Live Shape bug
SG... Aug 13, 2013 5:19 PM (in response to becca_s)Hi,
Use the Path Selection tool to target the shapes, and not the Move tool (which targets the layer(s)).
regards,
steve
7. Re: Photoshop CC Properties Panel Live Shape bug
ethan.beyer May 1, 2014 12:13 PM (in response to SG...)I've been having this problem, too, and I legitimately thought I was crazy. Whether I use the Selection Tool or the Move Tool, I still run into some shapes that refuse to show all their options.
With most every shape, if at least one of its points are selected via the Selection Tool, the Live Shapes options are editable within the Properties Toolbar. But some are not, regardless of how many points of the shape are selected.
8. Re: Photoshop CC Properties Panel Live Shape bug
philsmith1988 Oct 3, 2014 10:22 AM (in response to SG...)SG... wrote:
regards,
steve
SG... Why not make the Live Shape Properties appear when the Move Tool selects a layer, then Free Transform Path is activated? That is a deliberate gesture that is intuitive.
That seems more natural than having to use the Path tool or Direct Select tool, which feels more like an awkward hack than a natural flow.
Just making the Live Shapes selectable in the menu and/or assigning it a shortcut would be a step in the right direction.
Phil
