I am running RoboHelp 10 on Windows 7 Enterprise SP1 64 bit OS.
WebHelp is appending characters to the end of the TOC entry's URL address. The characters "bc-n" where n is a number are being generated for all of the TOC Page Entries when I generate WebHelp output. We are exporting the HTML files for import into an application. The TOC Page Properties Link to: property does not contain the characters in RoboHelp.
We have standardized names defined for our application and the appended characters are not going to work in the application.
When I use the generated html output in IE10 Version 10.0.9200.16635 Update Versions: 10.0.7 (KB2846071) the characters show up in the URL when I hover the mouse over the TOC entry as shown in the screenshot below.
The two screenshots show that the Link to property does not have the characters "bc-7" but the URL address does.
Is there a setting or way to configure RoboHelp to prevent Robohelp WebHelp from generating and appending characters to the end of the URL address for TOC Entries?
Need to use the camera icon in the Web interface to stick screenshots in your post - they get stripped out otherwise.
This image shows the Link To property of the TOC Page, Name is MainPageBidItems.
The image below shows the URL Address ending in MainPageBidItemsbc-7 at the bottom of the window
I have never known Rh add any characters so I think something else is at play here. Please open one of the sample projects and see what happens there. Click Open on the RoboHelp Starter page and then click Samples in the ribbon on the left.
@NealRob1026 - FYI your project location is really long - best practices dictate a structure like c:\projects\[name_of_project]\
