Every time I open a MXML file in one particular Flex Project, I get a Design Mode Preloading error message that states...Preparing the design mode for this MXML file is taking longer than usual, likely due to the complexity of the layout. Would you like to continue loading the Design Mode? It is really annoying and I assume there has to be some way to get rid of this. Anyone ever see this before?
Casey
cbentz,
If you don't need to use the Design View, you can turn it off. To do so, select Window from the Flash Builder menu and deselect Enable Design Mode.
Hope this helps,
Mallika Yelandur
Adobe Community Help & Learning
cbentz,
Hope this helps,
Mallika Yelandur
That solved the issue.
What if there is no design mode?
I installed FB 4.7 Trial version a few days ago. As you see in the screen shot below, there are no tabs to switch between source and design modes.
There isn't Enable Design Mode option in the Windows menu, too.
My Windows is 32 bit. Is it about this?
I think this is the answer: http://forums.adobe.com/message/5093899#5093899
