I keep getting this error message: Adobe Flash Player 11.6 r602 stopped working and was closed.
Uninstall and re-install.
Did several times to no avail.
You need to perform a clean install: http://forums.adobe.com/thread/928315
[topic moved to Flash Player forum]
Could not delete the Macromed/Flash, as an error message says that I need permission to do so. How do I get that?
You are logged-in as Administrator user?
I loggin by selecting "Run as Administrator". Does this qualify as being logged-in as Admministrator? If so, this still does not allow deletion of the intended file.
Thanks for your suggestions.
Use File Assassin. If it can't remove it. it CAN'T BE REMOVED.
