1. Re: Premiere Pro CC Keeps Crashing when exporting h.264
JSS1138 Aug 18, 2013 8:13 AM (in response to Kens10)Are those stopping points consistent, or random?
2. Re: Premiere Pro CC Keeps Crashing when exporting h.264
Kens10 Aug 18, 2013 9:18 PM (in response to JSS1138)They are random Jim.
3. Re: Premiere Pro CC Keeps Crashing when exporting h.264
JSS1138 Aug 19, 2013 9:10 AM (in response to Kens10)Sorry, I don't have any other solid ideas. Possibly a bad install, possibly overheating, or a bad piece of hardware.
You could try exporting out a DI and converting that to the desired H.264, either using AME or some other tool.
4. Re: Premiere Pro CC Keeps Crashing when exporting h.264
Kens10 Aug 19, 2013 9:30 AM (in response to JSS1138)No problem Jim. I just created a new project as a test and imported the video clip which is about 40 minutes and exported it without any editing and did fine. I don't know why cs6 tells me the project is damaged and can not open when it opens fine in CC. But seems it has to do with something on my timeline. Wwhen I do short exports of different locations based on where it stops it works fine. I really don't want to start the project over but looks like I might have too.
5. Re: Premiere Pro CC Keeps Crashing when exporting h.264
Kevin-Monahan Aug 19, 2013 10:18 AM (in response to Kens10)Hi Kens10,
It might be due to a video driver. See this forum post and see if anything suggested will help you: http://forums.adobe.com/thread/1235582
Kevin
6. Re: Premiere Pro CC Keeps Crashing when exporting h.264
Kens10 Aug 19, 2013 10:29 AM (in response to Kens10)Finally figured out the problem. Hope this helps other casual users like myself. Originally when I started editing I unlinked the video from audio to make some audio specific edits. This was a game play shoot of the board game only and talking heads were not in the shot. Once I finished the editing I linked the video audio tracks back together. After I inspected the timeline thoroughly by zooming in to check every edit I was out of sync on one of my edits and it had a red -4 on video and a plus +4 on audio right at the edge of the clips. After unlinking the tracks again the red numbers went away and sure enough had a successful export in H.264 after at least a dozen crashes. What's funny about this is I had a successful export with mpeg2 after continuous h.264 and flv crashes till this fix.
7. Re: Premiere Pro CC Keeps Crashing when exporting h.264
Kevin-Monahan Aug 19, 2013 10:41 AM (in response to Kens10)Hi Kens10,
Thanks for the report.
Kevin
