Can I have the checkbox caption highlighted in a color when the box is checked?
Avatar
Level 1
I'm trying to make a PDF fillable form for some of my sales folks, and I would love to highlight the color of the caption text associated with a checkbox when said checkbox is selected.
Is this possible?
Thank you all!
Avatar
Level 4
Use the below script
  if(this.rawValue == 1)
   this.fontColor = "255";
else
  this.fontColor = "0";
endif
Hope it helps
Vipin
Avatar
Level 1
Hi Vipin!  Thanks for the script!
The only problem is...  when I add it to the checkbox, only the check MARK itself changes color, not the text associated with the checkbox as a caption.
Can you advise?  Thank you, my friend!
Avatar
Level 1
I also tried this:
this.caption.font.fill.color.value = "255,0,0";
Still, not working.  Weird, huh?
I found this unanswered comment here, which seems to be addressing the same issue, but we're using exactly the same script!  I wonder why it's not working?
http://forums.adobe.com/thread/601932
Avatar
Level 4
It is working at my end, I have uploaded the PDF file, check the below URL
https://workspaces.acrobat.com/?d=4x-kqQXOfx376GZhBhjsGA
Avatar
Level 1
Ugh.  Very odd.  I tried your script, but I still cannot get it to work.
I'm using LiveCycle Designer ES Version 8.2.1.4029.1.523496
I had it on MouseUp, but I changed it to Click -- still nothing.  Just the checkmark.  :-(
Avatar
Level 4
The PDF that i have uploaded still not working?
I have created this PDF in designer 10.
Avatar
Level 1
Still not working.  I hate to give up, I just don't have much more time to work it through.  I tried everything I could think of, with no result.  I copied your checkbox, I copied the script, I tried several permutations on the script, nothing.
What could be the issue?
