disable enter
Guest
Mar 11, 2007 Mar 11, 2007
Hi i have a text area, which i need to stop users from using the enter key
ie
inside the text area the user can only use the spacebar and can NOT use the enter key to space out words
how can this be done?
Advanced techniques
655
LEGEND , Mar 12, 2007 Mar 12, 2007
craiglaw98 wrote:
> ok i have tried that using this
> <cfset texttosend = REReplace(form.message, "(Chr(13)|Chr(10))", " ", "ALL")>
> then i inserted '#texttosend#' into a table in my database, but the enters
> still appear?
> any ideas what i need to do
sorry, my fault. here's correct code:
<cfset texttosend = REReplace(form.message, "(#Chr(13)#|#Chr(10)#)", "
", "ALL")>
... i forgot the pound signes around Chr(xx)...
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com
why do you want to prevent the use of Return/Enter key in your textarea?
if it has to do with formatting of user's input for stroing/isplay, then
there are other things you should be doing instead of disabling keys...
otherwise, google for "javascript disable enter key" - you will have to
write a js function to treat Enter/Return as a space inside your textarea
Azadi Saryev
Sabai-dee.com
Guest
ok the text area is a text area for sms text, if a user presses enter, the sms message gets cut off where the enter has been clicked.
ie if a user types
hello paul (enter)
what wrong
only the hello paul goes through
so i need to stop the user from using the enter key inside the text box
i see..
well, you can use Replace() function on the user's input string to
replace all Chr(10) and Chr(13) with " " (space) before sending the
sms... or use a regex:
#REReplace(form.textareaname, "(Chr(13)|Chr(10))", " ", "ALL")#
Azadi Saryev
Sabai-dee.com
Guest
ok thanks
what is Chr(10) and Chr(13) ?
does that = enter?
if so how can i do the replace and then cfset a session.message
they are equivalents of CR and LF (carriage return and line feed)
characters - which is what pressing Return key inserts into the textarea
(depending on the operating system, either one of them or both)
Azadi Saryev
Sabai-dee.com
Guest
Ok so if i use
how do i set the new version without returns as a session
if i understand you correctly:
you have a form where a user can type some text to send as sms;
lat's say that textarea in the form is named "smstext";
in the form's action page (in the code that processes form submission)
you will <cfset texttosend = REReplace(form.smstext,
so now the sms text without line feeds or carriage returns is stored in
the "texttosend" variable.
if you need to store that in the session scope, just do <cfset
session.texttosend = REReplace(form.smstext, "(Chr(13)|Chr(10))", " ",
"ALL")> instead.
you can use whatever valid variable name you want instead of "texttosend".
don't forget to use your actual textarea's name instead of "smstext".
Azadi Saryev
Sabai-dee.com
Guest
then i inserted '#texttosend#' into a table in my database, but the enters still appear?
> still appear?
", "ALL")>
Azadi Saryev
Sabai-dee.com
Documentation
