Related Selects
Mar 11, 2007 Mar 11, 2007
I'm trying to get a couple of related selects working based on Dan Bracuk's code. Below I'll write my interpretation.
1 - On top of cfm page:
<cfquery name="Cliente" datasource="intraartis">
SELECT ClienteID, ClienteNome
FROM dbo.cliente_tbl
ORDER BY ClienteNome
</cfquery>
<cfquery name="Contacto" datasource="intraartis">
SELECT ClienteID, ContactoID, ContactoNome
FROM dbo.contactos_tbl
ORDER BY ContactoNome
</cfquery>
2 - Within the Head tags:
<script language="javascript">
<cfset idArray=ListToArray(ValueList(Contacto.ContactoID))>;
<cfset compareArray=ListToArray(ValueList(Contacto.ClienteID))>;
<cfset descriptionArray=ListToArray(ValueList(Contacto.ContactoNome))>;
function selectChange(selectedValue)
<cfoutput>
var #toScript(idArray, "theIdArray")#;
var #toScript(compareArray, "theCompareArray")#;
var #toScript(descriptionArray, "theDescriptionArray")#;
</cfoutput>
var i=0;
var j=0;
var len=theIdArray.length;
document.forms['ProjectoFrm'].Contacto.options.length=0;
for(i=0;i<len;i++)
if(theCompareArray==selectedValue)
document.forms['ProjectoFrm'].Contacto.options=new Option(theDescriptionArray,theIdArray);
j++;
return true;
</script>
3 - Inside of the form tags:
<cfselect query="Cliente" name="ClienteID" onChange="selectChange(this.Value);" value="ClienteID" display="ClienteNome" selected="#selectedCliente#"/>
<cfif existingrecord>
<cfselect query="Contacto" name="ContactoID" value="ContactoID" display="ContactoNome" selected="#selectedContacto#"/>
<cfelse>
<select name="ContactoID">
<option value="1">Not Updated</option>
</select>
</cfif>
4. It comes up with the COLDFUSION error: Variable SELECTEDCLIENTE is undefined.
Viewing the source of the page, the arrays are built.
Could Dan Bracuk or someone else give me some help?
Thanks.
Manuel
Advanced techniques
609
I don't see you setting a variable named selectedCliente anywhere.
In the page where my code resides, there is a third query that looks for existing values. If there are none, which means I will be inserting rather than updating records, I have defaults. Right now that code is at work and I am not.
Thanks Dan for your reply.
I´m pasting your code as it is on the post of 02/26/2007:
I only had to do this once, and it works. Here it is
<cfquery name="Etiology" datasource="burns">
select EtiologyID, Etiology
from burns_Etiology
where show = <cfqueryparam cfsqltype="cf_sql_char" value="Y">
</cfquery>
<cfquery name="EtiologyDetail" datasource="burns">
select EtiologyID, EtiologyDetailID, detail
from burns_EtiologyDetail
</cfquery>
// arrays to make selectcontrol script work
idArray = ListToArray(ValueList(EtiologyDetail.EtiologyDetailID));
compareArray = ListToArray(ValueList(EtiologyDetail.EtiologyID));
descriptionArray = ListToArray(ValueList(EtiologyDetail.detail));
another query for the current value, if applicable
<script language="JavaScript">
// changes the options for etilogy detail based on selection of etiology
<cfoutput>
</cfoutput>
var i = 0;
var j = 0;
var len = theIdArray.length;
// clear the detail select control
document.forms['dataForm'].EtiologyDetail.options.length = 0;
for ( i = 0; i < len; i++)
if (theCompareArray == selectedValue)
document.forms['dataForm'].EtiologyDetail.options = new Option(theDescriptionArray,theIdArray);
j++;
} // end if
} // end loop
return true;
} // end function
</script>
Function gets called here
<th>Etiology</th>
<td><cfselect query="Etiology" name="Etiology" onChange="selectChange(this.value);"
value="Etiologyid" display="Etiology" selected="#selectedEtiology#" />
</td>
<th>Detail</th>
<td colspan="3">
<cfselect query="etdetail" value="EtiologyDetailID" display="detail"
name="EtiologyDetail" selected="#selectedEtiologyDetail#" />
<cfelse>
<select name="EtiologyDetail" >
</select>
</cfif>
I don´t see where you set the variable "selectedEthiology".
Hope this helps.
It was in the part of the code that I didn't copy.
Mar 12, 2007 Mar 12, 2007
Thanks again.
Could you either paste the missing part of the code or help me with the code that I have?
Also, I tried to remove the selected attribute. It also comes up with the error "variable existingrecord is undefined".
Apreciate your help.
Manuel
Start with the fundamentals. You can't use a variable until you define it somewhere. Common ways to define variables are cfset and cfscript.
The page that I wrote is used to either add records to a db, or update them. Hence the name of the variable, existingrecord. Is that what you are trying to achieve? I already hinted as to how I came up with that variable. You have to read more than the code snippets.
Documentation
