Dynamically Evaluating the value of column list
Participant ,
Mar 12, 2007 Mar 12, 2007
I am trying to create and auto manitaining form based on columlist coming back from a query. How can I get the dynamic value of the items. I played around trying to do a query of queries. Somehow, it is just not working. Can someone please tell me how to get the value to place it in the input box.
<cfif isdefined("theSQLQuery2")><cfdump label="SQL" var="#theSQLQuery2#"></cfif>
<cfquery dbtype="query" name="getthis">
Select * from theSQLQuery2
</cfquery>
<cfdump var="#getthis#">
<h3>Create configuration settings</h3>
<table width="800" border="1" cellspacing="0" cellpadding="0">
<cfloop list="#theSQLQuery2.ColumnList#" index="ColumnList">
<tr>
<th scope="row"><cfoutput>#ColumnList#</cfoutput></th>
<td><input name="<cfoutput>#ColumnList#</cfoutput>" type="text" value="" size="30"></td>
</tr>
</cfloop>
</table>
Advanced techniques
603
what is it you are trying to do exactly?
will <cfgrid> be your solution?
if not, try giving your cfloop's index a different name (change
index="ColumnList" to, say, index="ColumnName") - you are possibly
creating a variable confusion there by using same name for index as a
built-in CF var...
Azadi Saryev
Sabai-dee.com
Vientiane, Laos
http://www.sabai-dee.com
Participant ,
This worked for me.
</cfquery>
<cfloop list="#theSQLQuery2.ColumnList#" index="ColumnName">
<tr>
<th scope="row"><cfoutput>#ColumnName#</cfoutput></th>
<td><input name="<cfoutput>#ColumnName#</cfoutput>" <cfif ColumnName EQ "CONFIGID">type="hidden"<cfelse>type="text"</cfif> value="<cfoutput>#Evaluate("theSQLQuery2." & ColumnName)#</cfoutput>" size="30"></td>
</tr>
</cfloop>
</table>
I know I am taking a performance hit with evaluate. Is there a better way of doing this.
quote:
Originally posted by: cutie369
This worked for me.
</cfquery>
<tr>
</tr>
</cfloop>
</table>
You are also taking a performance hit by returning the entire table to cold fusion when all you want is the columnlist. Add "where 1 = 2" to your query to speed things up.
Advocate ,
I believe query variables can be accessed using the following notation:
QueryName["QueryColumn"][row]
So in your case, you might be able to use:
<input name="<cfoutput>#ColumnName#</cfoutput>" <cfif ColumnName EQ "CONFIGID">type="hidden"<cfelse>type="text"</cfif> value="<cfoutput>#theSQLQuery2[ColumnName][1]#</cfoutput>" size="30">
Participant ,
That worked nicely. Thanks for the tip. Now another question. How might I sort those column names?
create a temp array (i.e. <cfset myArr = ArrayNew(1))
use ListToArray() on your list
use ArraySort()
cfloop over the array or use ArrayToList() to convert back to list and
loop over it
look up those functions in the reference/livedocs
Azadi Saryev
Sabai-dee.com
Vientiane, Laos
Correction: no need for the first step:
Azadi Saryev
Sabai-dee.com
Vientiane, Laos
Mar 13, 2007 Mar 13, 2007
The following is without evaluate() and might help. The same for cfLoop and cfOutput:
<cfloop query="myQuery">
<cfloop index="myColumn" list="#myQuery.ColumnList#">
#myQuery[myColumn][CurrentRow]#
</cfloop>
</cfloop>
<cfoutput query="myQuery">
</cfloop>
</cfoutput>
Documentation
