We have recently upgraded to CF10.
Our application uses cfchart for reports.
In a standard request the charts work perfectly. We create png images en the publish them. All server activit
<cfchart name="cfChartData" format="png" chartWidth="650" chartHeight="200" rotated="yes" show3d="false" >
<cfchartdata item="item 1" value="20">
<cfchartdata item="item 2" value="50">
<cfchartdata item="item 3" value="10">
<cfchartdata item="item 4" value="35">
</cfchart>
When I try to use this through a gateway (cfml type) is returns the folowing exception:
"Error","Thread-22","08/21/13","14:13:36",,"Error invoking CFC for gateway netqromeventgateway: null {GATEWAYTYPE={CFMLGateway},ORIGINATORID={CFMLGateway},DATA={{ACTION={testChart}}},GATEWAYID={netqromeventgateway}}."
java.lang.NullPointerException
at coldfusion.tagext.html.ajax.AjaxRBFileMap.getRBFileName(AjaxRBFileMap.java:66)
at coldfusion.tagext.html.ajax.AjaxRBFileMap.importResourceBundleJS(AjaxRBFileMap.java:52)
at coldfusion.tagext.html.ajax.HtmlAssembler.importJS(HtmlAssembler.java:958)
at coldfusion.tagext.html.ajax.HtmlAssembler.importJS(HtmlAssembler.java:854)
at coldfusion.tagext.html.ajax.HtmlAssembler.importJS(HtmlAssembler.java:820)
at coldfusion.tagext.io.ChartTag.doStartTag(ChartTag.java:1078)
at cfnetQROMEventGateway2ecfc866926243$funcONINCOMINGMESSAGE._factor0(E:\apps\productie\netqrom\model\eventgateway\netQROMEventGateway.cfc:25)
could someone help us.
System Information
Server Details
Server Product ColdFusion
Version ColdFusion 10,283922
Tomcat Version 7.0.23.0
Edition Enterprise
Serial Number
Operating System Windows Server 2008 R2
OS Version 6.1
Adobe Driver Version 4.1 (Build 0001)
JVM Details
Java Version 1.7.0_15
Exact same error Vishu.
But we don't use cfcproxy and a cf build higher then:
Fixed In Build 282653
Thanx for your help!!
Hi Vishu#13,
Can I conclude from this report (https://bugbase.adobe.com/index.cfm?event=bug&id=3231445)
that it is a known issue and has not been resolved by Adobe?
Everything works perfectly in CF 9
The only way out for me now is to downgrade our CF 10 to CF 9.
Our client needs to be up and running next week.
This problem is a very iritating bug in CF10 and is still not to be fixed by Adobe.
We have now downgraded our CF10 install to CF9.
This 2 hours installation proces solved all our CF10 problems.
We are going to stay far away from CF10 until Adobe solves a number of bugs
Jurriaan Balleur
Jurriaan, do you mean to say you've paid for a CF10 upgrade, and this prevents you from using it?
Or we your still just testing stuff, and it means you won't be buying a CF10 upgrade?
Adam
Hi Adam,
We have an application thats works in CF8 and CF9.
Our new customer wanted to host our application in house behind their own firewall.
So we first tried to use CF10.
We where very frustrated that our havily used gateway functions dit not worked as we expected on cf10.
The timelimit to debug and test al the situations was quite critical. To get is to work for sure we downgraded the CF10 license to a CF9 license.
After 2 hours all was working perfectly in CF9 en we delivered the application the same day.
I'm sorry, I should have made a free standing repro for this case but our CF10 instance is al ready deleted.
In the furture I will defenitly make a proper repro.
for now every thing works like a charme in CF9
Thanksd
I've a) verified this as working in CF9 and broken in CF10; b) provided a free-standing repro case for it. See http://cfmlblog.adamcameron.me/2013/08/the-process-of-creating-clear-repro.html.
Adam
