Suspend History State (Undo Once)
Mycort Aug 19, 2013 11:39 AMI can't seem to get the suspendhistory code to work right in my script. I have a text script that reads the info of a text layer and displays it's info in another text layer......but it seems to have many states in between. I want to just undo from the first and last state only so that it undo's everything at once. Right now, i have to undo many times.
Also, it seems to create another text info layer that is not suppose to.
Can someone help me figure out why my script does not undo all the way?
if (app.documents.length > 0) {
var myDocument = app.activeDocument;
myDocument.suspendHistory("this will show up in the history panel", "multiselectfontreader()");
function multiselectfontreader() {
app.bringToFront();
main();
function main() {
if (!documents.length) return;
var selLayers = [];
selLayers = getSelectedLayersIdx();
for (var a in selLayers) {
makeActiveByIndex(selLayers[a], false);
//amend to suit.
readTextLayer()
function getSelectedLayersIdx() {
var selectedLayers = new Array;
var ref = new ActionReference();
ref.putEnumerated(charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt"));
var desc = executeActionGet(ref);
if (desc.hasKey(stringIDToTypeID('targetLayers'))) {
desc = desc.getList(stringIDToTypeID('targetLayers'));
var c = desc.count
var selectedLayers = new Array();
for (var i = 0; i < c; i++) {
try {
activeDocument.backgroundLayer;
selectedLayers.push(desc.getReference(i)
.getIndex());
} catch (e) {
.getIndex() + 1);
} else {
ref.putProperty(charIDToTypeID("Prpr"), charIDToTypeID("ItmI"));
ref.putEnumerated(charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt"));
try {
selectedLayers.push(executeActionGet(ref)
.getInteger(charIDToTypeID("ItmI")) - 1);
} catch (e) {
.getInteger(charIDToTypeID("ItmI")));
return selectedLayers;
function makeActiveByIndex(idx, visible) {
var desc = new ActionDescriptor();
ref.putIndex(charIDToTypeID("Lyr "), idx)
desc.putReference(charIDToTypeID("null"), ref);
desc.putBoolean(charIDToTypeID("MkVs"), visible);
executeAction(charIDToTypeID("slct"), desc, DialogModes.NO);
// Read one or more selected fonts
function readTextLayer() {
var myDoc = app.activeDocument;
var myLayer = myDoc.activeLayer;
if (myLayer.kind == LayerKind.TEXT) {
var thisText = myLayer.textItem;
// Renaming the Justifcation info from Justification.CENTER - > Center;
try {
var theJustification = String(thisText.justification)
.replace("Justification.", "")
} catch (e) {
var theJustification = "LEFT"
theJustification = theJustification[0] + theJustification.slice(1, theJustification.length)
.toLowerCase();
var fonts = getFonts(app.activeDocument.activeLayer);
for (var i = 0; i < fonts.length; i++) {
addTextLayer(
((fonts.length > 1) ? fonts[i].text + ((fonts[i].text.length) ? "\r" : '') : '') + "Font: " + fonts[i].font + "\r" + "Size: " + fonts[i].size + "\r" + "Color: #" + fonts[i].color.rgb.hexValue + "\r" + ((i === 0 && fonts[i].leading !== '') ? "Leading: " + fonts[i].leading + "\r" : '') + ((i === 0) ? "Justify: " + theJustification + "\r" : ''),
"Font Info #" + (i + 1),
[myLayer.bounds[0] + i * 150, myLayer.bounds[3] + 15]
// Add's a text layer which contains the content of the read string above
function addTextLayer(theText, theName, thePosition) {
var aTextLayer = app.activeDocument.artLayers.add();
aTextLayer.kind = LayerKind.TEXT;
aTextLayer.name = theName;
var aTextLayerRef = aTextLayer.textItem;
aTextLayerRef.kind = TextType.POINTTEXT;
aTextLayerRef.size = 10;
aTextLayerRef.font = "Arial-BoldMT";
aTextLayerRef.color = app.foregroundColor;
aTextLayerRef.justification = Justification.LEFT;
aTextLayerRef.position = thePosition;
aTextLayer.blendMode = BlendMode.NORMAL;
aTextLayer.opacity = 100;
aTextLayer.fillOpacity = 100;
aTextLayerRef.useAutoLeading = true;
aTextLayerRef.leading = 0;
aTextLayerRef.horizontalScale = 100;
aTextLayerRef.verticalScale = 100;
aTextLayerRef.contents = theText;
aTextLayerRef.antiAliasMethod = AntiAlias.SHARP;
//Move the newly created font layers into the existing "Pixel Spec" folder
var doc = app.activeDocument;
var srcLayer = doc.activeLayer;
try {
moveLayerToSet(doc, srcLayer, 'Pixel Specs');
} catch (error) {
false;
function moveLayerToSet(doc, srcLayer, toLayerName) {
var destLayer = doc.layers[toLayerName];
if (destLayer.layers) destLayer = destLayer.layers[0];
srcLayer.move(destLayer, ElementPlacement.PLACEBEFORE);
function getColorFromDescriptor(colorDesc, keyClass) {
var colorObject = new SolidColor();
switch (keyClass) {
case "Grsc":
colorObject.grey.grey = color.getDouble(charIDToTypeID('Gry '));
break;
case "RGBC":
colorObject.rgb.red = colorDesc.getDouble(charIDToTypeID('Rd '));
colorObject.rgb.green = colorDesc.getDouble(charIDToTypeID('Grn '));
colorObject.rgb.blue = colorDesc.getDouble(charIDToTypeID('Bl '));
break;
case "CMYC":
colorObject.cmyk.cyan = colorDesc.getDouble(charIDToTypeID('Cyn '));
colorObject.cmyk.magenta = colorDesc.getDouble(charIDToTypeID('Mgnt'));
colorObject.cmyk.yellow = colorDesc.getDouble(charIDToTypeID('Ylw '));
colorObject.cmyk.black = colorDesc.getDouble(charIDToTypeID('Blck'));
break;
case "LbCl":
colorObject.lab.l = colorDesc.getDouble(charIDToTypeID('Lmnc'));
colorObject.lab.a = colorDesc.getDouble(charIDToTypeID('A '));
colorObject.lab.b = colorDesc.getDouble(charIDToTypeID('B '));
break;
default:
return null;
return colorObject;
// get fonts and other parameters used in type layer
function getFonts(textLayer) {
function markReturnedContentText(text) {
if (font_content_detection) {
return font_content_detection_symbols[0] + text + font_content_detection_symbols[1] + "\r";
} else {
return '';
if (textLayer.kind == LayerKind.TEXT) {
app.activeDocument.activeLayer = textLayer;
var layerDesc = executeActionGet(ref);
var textDesc = layerDesc.getObjectValue(stringIDToTypeID('textKey'));
var rangeList = textDesc.getList(stringIDToTypeID('textStyleRange'));
var fonts = [];
for (var m = 0; m < rangeList.count; m++) {
var styleDesc = rangeList.getObjectValue(m)
.getObjectValue(stringIDToTypeID('textStyle'));
var aFrom = rangeList.getObjectValue(m)
.getInteger(stringIDToTypeID('from'));
var aTo = rangeList.getObjectValue(m)
.getInteger(stringIDToTypeID('to'));
if (m > 0) {
if (rangeList.getObjectValue(m - 1)
.getInteger(stringIDToTypeID('from')) == aFrom && rangeList.getObjectValue(m - 1)
.getInteger(stringIDToTypeID('to')) == aTo) continue;
var theLetters = app.activeDocument.activeLayer.textItem.contents.substring(aFrom, aTo);
var aFont = styleDesc.getString(stringIDToTypeID('fontPostScriptName'));
//var aSize = styleDesc.getUnitDoubleValue(stringIDToTypeID('size')) + " " + typeIDToCharID(styleDesc.getUnitDoubleType(stringIDToTypeID('size')));
var aSize = new UnitValue(styleDesc.getUnitDoubleValue(stringIDToTypeID('size')), "px");
var aColor = getColorFromDescriptor(styleDesc.getObjectValue(charIDToTypeID("Clr ")), typeIDToCharID(styleDesc.getClass(charIDToTypeID("Clr "))));
if (styleDesc.hasKey(stringIDToTypeID('leading'))) {
var aLeading = new UnitValue(styleDesc.getUnitDoubleValue(stringIDToTypeID('leading')), "px");
} else {
var aLeading = "";
var txt = theLetters.replace(/^\s+/, '').replace(/\s+$/, '');
var merged = false;
if (txt.length > 0) {
for (var x = 0; x < m; x++) {
try {
if (fonts[x].font === aFont && fonts[x].size === aSize && fonts[x].color.rgb.hexValue === aColor.rgb.hexValue && fonts[x].leading === aLeading) {
// It's a hack!!!
if (fonts[x].text !== txt) {
fonts[x].text += markReturnedContentText(txt);
merged = true;
} catch (e) {}
if (!merged) {
fonts.push({
text: markReturnedContentText(txt),
font: aFont,
color: aColor,
leading: aLeading
return fonts;
