Hi there,
I have made a [test] Form in Indesign CS6 that require to select for example three check boxes before you get the correct answer, is there a way to do this in LiverCycle.
here is PDF file that export from indesign:
https://dl.dropboxusercontent.com/u/72277778/check%20box%20indesign.pdf
here is the LiveCycle PDF that coverted from the above file:
https://dl.dropboxusercontent.com/u/72277778/check%20box%20test.pdf
LiveCycle Designer v.9
Windows 7
Retrieving data ...
