Disabling auto advance slides?
Mar 12, 2007 Mar 12, 2007
Hello all, in powerpoint/presenter, how do u disable the auto advance of slides once content has been uploaded onto breeze? It always seems to stick to 5 seconds even if u manually alter the timiings or disable them altogether!!
Presenter
533
Guest
Mar 13, 2007 Mar 13, 2007
While you're still in PowerPoint, before you publish, Select the Presentation Settings option under Breeze from your alt bar. On the "settings" tab is an option to set how long the slides will wait (default is 5 seconds, and setting to 0.0 results in a playbar issue, so I suggest 0.1 seconds). Keep in mind you probably also want to change each slide to "advance by user", which is a checkbox under "Slide Properties" for each slide.
v/r
Marc B
Mar 19, 2007 Mar 19, 2007
will give it a go, many thanks
Help resources
