CP7 Interaction not working in HTML5
Aug 26, 2013 Aug 26, 2013
I'm using the Tabs interaction in CP7 to present information.  It works perfectly in web preview, but not in HTML5.
I created a new one, and it works OK in HTML5, but it has 4 tabs and I only need three.
I can't see where to remove the 4th tab, though I apparently did it before (and don't remember how).  I'm wondering if removing it was what messed up the widget in HTML5.
Does anyone have any ideas?
Getting started
705
LEGEND , Aug 26, 2013 Aug 26, 2013
Hi there
Yeah, sometimes these beasties aren't all that intuitive. Try double-clicking the tab label area. It may require lots of double-clicking. You will finally get into a mode where you may change the label. Once you are there, you should see a circle with a minus symbol. Click that and the tab should be removed.
Cheers... Rick
Marion,
I cannot help your with not working in HTML5, already used that interaction and it worked for me.
To delete a tab, select one in the editing dialog box for the interaction, there is a small minus sign at the bottom that allows you to delete a Tab.
Lilybiri
Lieve, are you on the subscription? I ask because mine doesn't seem to work that way. Perhaps it was modified in the subscription version?
Cheers... Rick
Rick, sorry it is not at the bottom, it is to the left of the Button label for a tab in this case, when getting that label in editing mode, forgot to check.
Not sure if I am on subscription... don't think so.
Lilybiri
Hi there
Cheers... Rick
Found it! Thanks, Rick. Lieve, I didn't see the minus sign you have,
either.
Thanks both!
Help resources
