1 Reply Latest reply: Aug 26, 2013 2:14 PM by RAOmilctr RSS
    TOC Entries from Numbered Paragraphs are Out of Order
    RAOmilctr Community Member
      I have a book and related documents. Strewn throughout the documents are several graphics, with which I have used the Live Captions feature. The numbered paragraphs generate with the correct figure number in the text frame to which they are added. However, when generating a TOC for the Book, and including related book documents, my paragraphs do not list in order when there is more than one figure (instance of the numbered paragraph) on the same page. This occurs whether I have Sort Entries in Alphabetical Order checked or not.
      Thus, I have a graphic at the top of page, Figure 01, and a graphic at the bottom of page, Figure 02. For some reason, the TOC places Figure 02 above Figure 01 in the TOC:
      Figure 02 - This is the second graphic for the document....... 1
      Figure 01 - This is the first graphic for the document............. 1
      I created a new document, and just placed six instances of the Caption style I created, and they all have the correctly ordered  numbered paragraph. Figures 01 through 06. The captions are out of order on the page, however, in the following way:
      Figure 01 - Caption 1
      Figure 02 - Caption 2
      Figure 03 - Caption 3
      Figure 04 - Caption 5
      Figure 05 - Caption 6
      Figure 06 - Caption 4
      These entries feed into the TOC correctly; in figure order as above, or when Sort Entries in Alphabetical Order is checked, they change order and alphabetize, based on the caption, thusly:
      At the same time the entries in the previous document chapter, are still out of order, so the entire TOC looks like this:
      Figure 1-02 - This is the second graphic for the document
      Figure 1-01 - This is the first graphic for the document
      Figure 2-01 - Caption 1
      Figure 2-02 - Caption 2
      Figure 2-03 - Caption 3
      Figure 2-06 - Caption 4
      Figure 2-04 - Caption 5
      Figure 2-05 - Caption 6
      Things I have tried to remedy the situation:
      Saw in a Google search that the order of the placement of the enclosing frame on the page determines the TOC order, so I ensured that the first graphic was leftmost at the top paragraph of the page. No change in sort order of the TOC entries.
      Saw that the order in which graphics are added to the document determines the TOC order, so I cut all graphic elements out of page, and carefully re-pasted each in the order they should be in. No change. Tried reverse order, pasting last graphic first, and first last. No change in behavior.
      I have updated all book/document numbering from the shortcut menu in the Book tab window. Updated TOC, and no change.
      On a lark, I copied all of the document contents to a new document for the book, and added the document to the book in last position. I then updated the numbering again, and updated the TOC. It looked like this:
      Figure 3-02 - This is the second graphic for the document
      Figure 3-01 - This is the first graphic for the document
      Now, at this point, I just have to ask, WTH? The documents are in 1 - 2 - 3 order for the book, but the TOC re-sorts the Caption style entries to the order 1 - 3 - 2? What in the world is going on???
      Any help or suggestions for this would be greatly appreciated.
      Rich
        • 1. Re: TOC Entries from Numbered Paragraphs are Out of Order
          UPDATE
          As it turns out, the intial two graphics, which are anchored frame groups, with a graphic and the live caption were both anchored at the left margin of the main text frame for the page.
          However, graphic 1 was 3.5 inches wide, and graphic 2 was 4 inches wide. Thus the associated text frames in each repsective group was 3.5 and 4 inches as well. Regardless of where the frames were anchored within the main text frame, the width of the frame group was determining the TOC order. After making the first graphic 4 inches wide as well, the TOC, for the first two entries at least, is ordered correctly. Well it was always ordered correctly as ID saw it, but not as I saw it.
          Still trying to figure out why the later chapter was placed above the second chapter, however.
          Thx
