1 Reply Latest reply: Aug 27, 2013 12:05 PM by sinious RSS
    XML attribute 'with' reserved?
    Damon Edwards Community Member
      While working on a XMPP implementation I'm noticing the attribute 'with' keeps throwing errors when trying to access it to set or get the data from it. Is that a reserved word or something? Sort of makes this difficult considering 'with' is used heavily in the spec..
      var xml:XML = <rootNode>
                <item with="test" without="rest">cool</item>
      </rootNode>;
      trace(xml.item.@without); // no problem
      //trace(xml.item.@with); // uncomment and you'll get error "Syntax error: expecting identifier before with."
