SOLVED
Exclude Negative Numbers?
Avatar
Level 1
Is there a way to exclude negative numbers from appearing in numerical (currency) fields?
For instance, if a user were to attempt to enter a negative number in a given field, is there a way to instruct Adobe to erase the entry, or better yet, to prevent the user from doing so?
Thanking you in advance.
1 Accepted Solution
Avatar
Correct answer by
Employee
Hi Susan,
If you are using LC Designer, please use the following script on the exit event of the numeric field in the script editor box
if(NumericField1.rawValue<0)
NumericField1.rawValue="";
xfa.host.messageBox("Please Enter the positive value");
xfa.host.setFocus(NumericField1);
Let me know if that works,
Avatar
Correct answer by
Employee
Hi Susan,
Avatar
Level 2
Would I be able to possibly use similar function to ignore a drop down field that contains N/A?  Have 8 dropdowns that cotain "N/a, 1, 2, 3" and are all averaged out at the end but need N/A to be ignored if chosen??
Thanks so much n advnace for any help
Avatar
Employee
Hi 41globalit,
Please look into the example 2 attached in the sample file
~Pranav
Avatar
Level 2
This looks like exactly what I am looking for!! Will have to do some small tweaking I think to fit into my file!  Thanks so much!
Avatar
Level 2
Im not expert on coding.  What coding would I need to change?  All drop downs named DropDownList1, DropDownList2, DropDownList3, etc....
here is link to pdf if you'd like to view
http://41global.com/performeval.pdf
Thanks so much,
Message was edited by: 41globalit
Avatar
Level 2
For example 2 in your pdf, what would be the script i'd need to get things to average instead of it doing sum total??
