Locked
(C:\Windows\SysWOW64\FlashPlayerApp.exe:1224) could not be installed.
Guest
Aug 22, 2013 Aug 22, 2013
I have tried every which way I have found here to reinstall Adobe Flash Player.  The latest error message is the one I started with:  (C:\Windows\SysWOW64\FlashPlayerApp.exe:1224) could not be installed.
The download shows as installed and enabled.
My operating system is Windows 7, 64-bit; my browser is Internet Explorer, 32-bit.
10.3K
Aug 23, 2013 Aug 23, 2013
Guest
Aug 25, 2013 Aug 25, 2013
So, after following the instructions on the forum page you provided, the message was the installation was successful.  Now, when I go to any of the multiple test pages, they indicate I do not have flash player installed.
Aug 26, 2013 Aug 26, 2013
Guest
My version of IE is 10.0.8, so do the instructions in thread/885448 still apply?
When I went back to the downloads I have saved for flash player, I tried installing the second of the two downloads just now.  This version: install_flash_player 11.8 r800 gave me the same error message: (C:\Windows\SysWOW64\FlashPlayerApp.exe:1224).  The version I used the other day, and told you went through successfully, is install_flash_player_ax 11.8 r800.
So, with Windows 7, 64-bit and IE 10.0.8, 32-bit, which version install should I use?
I am literally performing the same tasks over and over again using the information in (too) many threads and coming up with the same end result.
Aug 27, 2013 Aug 27, 2013
If you only use Internet Explorer, then you only need to install the 'ax' (ActiveX) version.
And yes, the instructions in the earlier links apply to IE10 as well (they were written before there was any IE10).
Guest
Since I tried the install_flash_player 11.8 r800 when I shouldn't have, I did another uninstall.  I then restarted my computer, checked for the files and folders in thread 885448 and restarted my computer again.  I used the download I had saved of install_flash_player_ax 11.8 r800 and received the same error message.
So, I did not even attempted to enable flash player in IE, like you previously suggested.  As I already said, I am repeating the same steps over and over again from different threads and all of them result in the same error message when I try the download.
Which earlier version of flash player would be compatiable with my system:  Windows 7, 64-bit and IE 10.0.8, 32-bit?  Or, do you have another suggestion?
Aug 28, 2013 Aug 28, 2013
Any previous Flash Player version (e.g. 11.7.700.232) should work fine on Windows 7.
But we should also try to get to the bottom of that error; can you post the contents of the FlashInstall.log file in C:\Windows\syswow64\Macrome\Flash ?
Guest
My attempt to find the contents of the Flashinstall log file failed.  Would you send instructions on where to find this file?
Aug 29, 2013 Aug 29, 2013
It's in C:\Windows\syswow64\Macrome\Flash
Note that depending on your Explorer settings the .log suffix may not show.
Guest
Sep 02, 2013 Sep 02, 2013
When I search programs and files for C:\Windows\syswow64\Macrome\Flash, the search comes up "No items match your search."
Sep 03, 2013 Sep 03, 2013
Sorry, a typo crept in; the correct folder is C:\Windows\syswow64\Macromed\Flash
But don't search, use Windows Explorer to go there directly.
Guest
Here's what I got following your instructions.
The file shows as FlashInstall on your screenshot.  Open it with Notepad by double-clicking on it, then copy all its contents and post it back here in the forum.
Guest
Sep 04, 2013 Sep 04, 2013
=O====== M/11.8.800.94 2013-08-25+19-26-18.644 ========
0000 00000010 "C:\Users\karens0312\Downloads\install_flash_player_ax.exe"
0001 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0002 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0003 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0004 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0005 00000011 1
0006 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0007 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0008 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_8_800_94.ocx
0009 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe
0010 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.dll
0011 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0012 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0013 00001030 C:\Windows\SysWOW64\FlashPlayerApp.exe:1224
0014 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
=X====== M/11.8.800.94 2013-08-25+19-26-55.260 ========
=O====== M/11.8.800.94 2013-08-25+19-42-57.639 ========
0001 00000011 1
0002 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0003 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_8_800_94.ocx
0004 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe
0005 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.dll
0006 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0007 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0008 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0009 00001106
0010 00001106
0011 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
=X====== M/11.8.800.94 2013-08-25+19-43-39.038 ========
=O====== M/11.8.800.94 2013-08-27+00-04-38.626 ========
0000 00000010 "C:\Users\karens0312\Downloads\install_flash_player.exe"
0001 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
0002 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0003 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
0004 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0005 00000011 1
0007 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0008 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
0009 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0010 00001036 Software\Opera Software/Last CommandLine 2
0011 00001036 Software\Opera Software/Last CommandLine 2
0012 00001036 Software\Opera Software/Plugin Path 2
0013 00001036 Software\Opera Software/Plugin Path 2
0014 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_8_800_94.dll
0015 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_8_800_94_Plugin.exe
0016 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
0017 00000017 C:\Windows\SysWOW64\Macromed\Flash
0018 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_8_800_94.exe
0019 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0020 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
0021 00001030 C:\Windows\SysWOW64\FlashPlayerApp.exe:1224
0022 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0023 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
=X====== M/11.8.800.94 2013-08-27+00-05-13.583 ========
=O====== M/11.8.800.94 2013-08-27+23-04-01.464 ========
0000 00000010 "C:\Users\karens0312\Downloads\uninstall_flash_player.exe" -force
0001 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0002 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
0003 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0004 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
0005 00001021
0006 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0007 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0008 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0009 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0010 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
0011 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0012 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0013 00001021
0014 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0015 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0016 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0017 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0018 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0019 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0020 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0021 00001036 Software\Opera Software/Last CommandLine 2
0022 00001036 Software\Opera Software/Last CommandLine 2
0023 00001036 Software\Opera Software/Plugin Path 2
0024 00001036 Software\Opera Software/Plugin Path 2
0025 00000011 1
=X====== M/11.8.800.94 2013-08-27+23-08-15.362 ========
=O====== M/11.8.800.94 2013-08-27+23-35-13.437 ========
0005 00000011 1
=X====== M/11.8.800.94 2013-08-27+23-35-47.022 ========
=O====== M/11.8.800.94 2013-08-28+21-44-56.994 ========
0001 00000011 1
0008 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
0009 00001030 C:\Windows\SysWOW64\FlashPlayerApp.exe:1224
0010 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0011 00001106
0012 00001106
0013 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
=X====== M/11.8.800.94 2013-08-28+21-45-44.761 ========
=O====== M/11.8.800.94 2013-09-02+19-36-33.869 ========
0000 00000010 "C:\Users\karens0312\AppData\Local\Adobe\AIH.745d0244abd9b6d488cf2f575e01675f91460909\install_flash_player_ax.exe" -install -iv 8 -au 1
0001 00000011 1
=X====== M/11.8.800.94 2013-09-02+19-36-54.804 ========
I have requested that someone from the Flash Player developers team have a look at your log file.
Adobe Employee ,
Sep 06, 2013 Sep 06, 2013
The error we're seeing here is stating that the Flash Player Settings Manager in the control panel is open or in use.  Since it's doubtful that it's actually open and visible, I suspect some other file/process has it partially locked and that is marking it "in use".
Can you try the steps outlined in this post and see if that helps work around the problem?
http://forums.adobe.com/message/4723798#4723798
Chris
Guest
Sep 11, 2013 Sep 11, 2013
Do I have to go through the 'kill process' as described in the SuzyQ post?  Or, do I find and delete the "Macromed" folder like in Bob's Windows\system32 folder?  Do I have to download, etc. Microsoft's Process Explorer for either, or both of these options?
You don't need Process Explorer, although it can be a useful tool.  Windows Task Manager (Processes tab) will do.  Try this
Guest
Sep 17, 2013 Sep 17, 2013
After following the instructions above, I ran the ActiveX installer which completed successfully.  I went to Adobe's website to test my computer for Flash Player; my computer does not show the video, etc.  Shockwave Flash Object is enabled under Manage AddOns.  Now what?
Do you have ActiveX Filtering enabled, by any chance?
Guest
Sep 18, 2013 Sep 18, 2013
No, I do not have ActiveX Filtering enabled.  (That answer is assuming I would be looking for this in Manage AddOns, like Shockwave Flash Object.
Sep 19, 2013 Sep 19, 2013
No, you would be looking under Tools | ActiveX Filtering
Guest
ActiveX Filtering has a check mark next to it.  That means it is enabled?
Sep 20, 2013 Sep 20, 2013
Yes; you need to disable it, otherwise it will block the Flash Player ActiveX control.
