Can I let users return to a "reset" interaction page? I have different caption boxes that appear depending on which object the user clicks. After the user navigates away from the page, if they go back to the page with the interaction, it looks as it did when they left it (that is, with the resulting caption box displayed). I'd like it to look as it did when they first saw it -- with the caption boxes hidden. "Visible in output" is not checked for these caption boxes, but when a user returns to the page, they're displayed. Any ideas? I'm using Cp7, and haven't published the course yet -- just using the Play button within Cp. Thanks!
Set up a Conditional Advanced Action that will hide or show all the elements required for the start of the slide.
Use the On Slide Enter event to trigger the Conditional Advanced Action.
Hello and welcome to the forum.
Rod always uses a conditional action I know the reason, but for your case a standard advanced action will do the trick as well.
I call those actions mostly initializing actions. Some tips: group all the text captions (or other text containers) that you have to hide, and then your On Enter action for the slide will be a one-liner
Hide Gr_all
I used the label 'Gr_all' to indicate the group of objects you want to hide, have a lot of examples on my blog, and in this YouTube video you'll see the grouping and hiding in action:
Advanced Actions in Captivate 6
Sorry, Rod, but I wanted to avoid to explain which condition to use. Have no idea if this 'new' visitor knows anything about advanced actions.
Lilybiri
Not a problem. I was just leaving the door open in case there might be situation where some of the objects on screen would be left as is due to certain conditions. Just being cautious.
I know your opinion about standard actions, Rod.
