Bullet indent incorrect
Participant ,
Sep 03, 2013 Sep 03, 2013
Using RH10, HTML to generate HTML help (.chm file).  First line indent for bullet incorrect:
Using the ruler in design view, and the indents appear to be correct:
The style descriptions is as follows:
The CSS is:
Any suggestions as to how I can get my first line indent to work correctly?
Thank you!
745
Remove the text-indent property from the style. You may need to amend the margin of the paragraph as well, otherwise you'll have a rather large indent from text to paragraph.
(text-indent only sets the indent for the first line of a paragraph.)
Greet,
Willam
Participant ,
Sep 04, 2013 Sep 04, 2013
Hi William:
I removed the text-indent property, and here is the generated result:
The following issues are now present:
  • The hanging indent for the second line is way off - how do I fix that?
  • It appears the bullet character has moved.  I base this conclusion on the paragraph that follows the bulleted line.  This paragraph should line up with the text in the bulleted line (for example, the word 'The' should line up with the word 'Open').
The CSS now looks like this:
Any suggestions???
Sep 05, 2013 Sep 05, 2013
What's the HTML of the list in Robo and the output?
Greet,
Willam
Participant ,
The HTML code from RoboHelp:
The HTML code from the output:
These appear to be the same to me - what are your thoughts?  I appreciate your help!
Tina
Participant ,
Maybe these screen shots would be easier to read:
HTML Robohelp:
HTML Output:
Participant ,
Still not very good screen shots, here's a copy of the HTML from RoboHelp:
face="Arial" size="2">To create a single operator operation:</font></b></span></h3>
<?rh-list_start class="rl-p-BulletedList" an="1" level="1" style="list-style: rh-list;
     list-style: rh-list;" ?><p class="BulletedList"><span
  style="font-family='Times: New Roman;"><a href="javascript:BSSCPopup('../Banner_Links/Open_Operation_Area.htm');"
             id="a2">Open</a> the operation
area and select </span>New &gt; Single Operator Operation.</p><?rh-list_end ?>
<p class="BulletedListPara">The operation header tab appears.</p>
HTML Output:
Sep 08, 2013 Sep 08, 2013
Tina
It looks like this is a project created before Rh8 when the CSS was written in a different way. The basic difference is that definitions that were in the paragraph style are now in the list style, where they should be.
Take a look at http://www.grainge.org/pages/authoring/lists/lists.htm on my site.
@petergrainge
RoboHelp Documentation
Download Adobe RoboHelp
