1. Re: "Sign in Required" Loop
Romsinha Sep 6, 2013 3:16 AM (in response to martenme)Hi martenme,
Please try the mentioned steps:
1. Right click on any of the CC apps and run as administrator.
2. Disable UAC, restart your machine and launch any app as run as admin: http://blogs.msdn.com/b/hyperyash/archive/2012/07/18/disabling-user-account-control-in-win dows-8.aspx .
3. Update CC desktop and try to sign in again: https://creative.adobe.com/products/creative-cloud .
4. Selective startup: http://windows.microsoft.com/en-in/windows-vista/run-selective-startup-using-system-config uration
5. enable hidden admin and try to activate again: http://www.howtogeek.com/howto/windows-vista/enable-the-hidden-administrator-account-on-wi ndows-vista/ .
Romit Sinha
2. Re: "Sign in Required" Loop
martenme Sep 6, 2013 3:18 AM (in response to Romsinha)Hi,
forgot to mention: I work under Mac OSX :-)
3. Re: "Sign in Required" Loop
Romsinha Sep 6, 2013 3:32 AM (in response to martenme)Hi martenme,
Navigate to Library/Application Support/Adobe/ right click /get info/ give read/write permission and select apply to enclosed item: http://www.macinstruct.com/node/415 .
Navigate to ~/Library/Application Support/Adobe/ and give read/write permission/ select apply to enclosed item: http://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html and try to sign in.
If the issue still persists then navigate to Library/Application Support/Adobe OOBE and rename to OOBE.old.
Navigate to ~/Library/Application Support/Adobe/OOBE and rename to OOBE.old
Download CC desktop: https://creative.adobe.com/products/creative-cloud and try to sign in again.
Start the system in safe boot and try signing in: http://helpx.adobe.com/x-productkb/global/start-safe-boot-mode-mac.html .
Enable root account and try to activate again: http://support.apple.com/kb/PH11331 .
Romit Sinha
4. Re: "Sign in Required" Loop
mrjonnywood Sep 6, 2013 3:51 AM (in response to martenme)I had a similar problem. Every time I opened a CC App, I was asked to sign in. I followed instructions on several forums, but nothing worked.
Yesterday I got in touch with Adobe Help and together we spent over two hours trying to resolve the problem. I have to say Khongyairong (the guy I was dealing with) was very helpful but we ran out of time as I had to go out.
Today, I decided to remove every single trace of Adobe from my Mac. I followed these steps and all now works as it should!
Please note the order – uninstall apps first, then run cleaner, then manually remove any left over files.
Warning: You will delete all Adobe files from your computer. If you are using any Adobe products other than Creative Cloud please make sure you check every file before deleting it – if it's not related to CC don't delete it! You might want to make a snapshot of your system that you can restore to before doing this. If there is more than 1 user on the Mac make sure they don't have Adobe products that could be effected by the following process.
- Use the Uninstallers for each App you have (uninstallers can be found in Applications/Adobe *App Name*/Uninstall Adobe *App Name*
- Check Applications/Utilities for any other Adobe Uninstallers and run them
- Use Creative Cloud Cleaner to remove everything else (I was given the download from Khongyairong so don't have the link)
- Select 'All' from the dropdown menu, top-right.
- Click 'Clean All'
- At this point I restarted my Mac but it may not be necessary.
- Go to /Library/Application Support and delete the entire Adobe folder (I also deleted the Macromedia folder too, but I think this is just for Flash Player)
- Go to /Library/Caches and delete all folders and files with 'Adobe' in the name
- Go to (User) ~/LibraryApplication Support and delete the entire Adobe folder
- Go to /Users/Shared/Library/Application Support and delete the entire Adobe folder (if you have more than one user set up make sure they are not using Adobe products that will not function correctly if you delete this folder)
- At this point I searched my entire computer for any other files or folders with Adobe in the name and deleted them
- There was also a Photoshop folder in one of the Librarys (can't remember which but check in both) I deleted that too
- I emptied the trash and restarted here and would recommend the same
At this point I could have started installing the software again, but I took some extra steps which involved 3rd party software. I use Onyx which is a very good tool to clean up OS X system. You can use this or something similar to do the following:
- Reset home folder permissions and ACLs
- Clear system and user caches
During the Onyx processes I was promted to restart my Mac a couple of times. Once all that was completed my Mac was booting up a fraction quicker than before (which was a nice bonus).
Fresh installs
I then went to creative.adobe.com, signed in and downladed Creative Cloud Desktop App – nothing else.
I installed CC desktop, signed in and initially downloaded 1 app (in my case Photoshop), opened it and waited... no window requesting sign in!!!!
I double checked, by quiting and reopening Photoshop – all seemed good!
I was then able to install other CC Apps (one by one just be sure) from the Creative Cloud App and every one of them works withut being promted to sign in!
Hope this works for you, I've seen this issue a lot and was very happy to have a solution to share it with others!
5. Re: "Sign in Required" Loop
martenme Sep 6, 2013 8:02 AM (in response to mrjonnywood)Thanks mrjonnywood! It worked!
6. Re: "Sign in Required" Loop
baddmojo67 Sep 7, 2013 1:36 PM (in response to martenme)Have the same issues on my Windows 7 64bit machine (yet my Mac at work is fine).
Once I shutdown an application or heaven for bid, reboot my system, it requires several login attempts to be able to actually run any cc application. The BS is that your supposed to be able to run apps without having to log in or even be online. (the only required login is supposed to be once every 180 days, yet mine is within 5 minutes of closing down and restarting)
Adobe does not have their stuff straight, as usual, and expects the user to jump through hoops to fix their problems. Nice job...
7. Re: "Sign in Required" Loop
GLW1961 Sep 7, 2013 7:10 PM (in response to martenme)I have not been able to sign into my subscription for 4 onths even though it comes out of my bank acct. every month.
When I click on the icon on my macbook it prompts me for a serial #.
8. Re: "Sign in Required" Loop
Jeff A Wright Sep 9, 2013 8:18 AM (in response to GLW1961)GLW1961 if you are being prompted to enter your serial number then please see http://forums.adobe.com/thread/1234635 where this topic is discussed.
9. Re: "Sign in Required" Loop
Flemming Rasmussen 123 Jun 20, 2014 10:45 AM (in response to mrjonnywood)It's been almost a year, and after installing the CC 2014 update yesterday i got the same problem.
Unfortunately your suggestions didn't work and neither did all other suggestions in these forums.
Spent an hour on the phone with Adobe support who had not heard about this issue earlier (they said). And could not help me resolve it.
10. Re: "Sign in Required" Loop
mwpro Jun 20, 2014 11:20 AM (in response to Flemming Rasmussen 123)Same thing happened to me. Updated and now I'm screwed. Did you ever find a fix. Tech support has been worthless thus far.
11. Re: "Sign in Required" Loop
Jeff A Wright Jun 20, 2014 11:29 AM (in response to mwpro)Please be aware that this discussion dates back from September 2013.
If you are receiving a sign-in error then please try removing the OPM.db file per solution 2 in CC desktop lists applications as "Up to Date" when not installed - http://helpx.adobe.com/creative-cloud/kb/aam-lists-removed-apps-date.html.
In addition I have personally installed questionable virus protection software which has caused this exact same behavior to occur. I would recommend also reviewing Sign in, activation, or connection errors | CC, CS6, CS5.5 - http://helpx.adobe.com/x-productkb/policy-pricing/activation-network-issues.html and try temporarily disabling your security software to see if the same behavior continues.
12. Re: "Sign in Required" Loop
Flemming Rasmussen 123 Jun 20, 2014 11:29 AM (in response to mwpro)nothing works except running in trial mode... but who knows how long that works... and so far that only works for Illustrator and Photoshop - not indesign
13. Re: "Sign in Required" Loop
Flemming Rasmussen 123 Jun 20, 2014 11:35 AM (in response to Jeff A Wright)Jeff A Wright - that's exactly what is disturbing - that there still an issue with this. Deleting the OPM file (which support also suggested) doesn't help.
And i have no antivirus installed on my mac either.
Adobe support have left me hanging with no solution...
14. Re: "Sign in Required" Loop
Jeff A Wright Jun 20, 2014 11:37 AM (in response to Flemming Rasmussen 123)Flemming Rasmussen 123 what is your case number from your contact with our support team? Also is all of your contact information up to date under your account at http://www.adobe.com/?
15. Re: "Sign in Required" Loop
Flemming Rasmussen 123 Jun 20, 2014 11:41 AM (in response to Jeff A Wright)Jeff A Wright - case number is 0185617726 and yes my contact info is up to date.
16. Re: "Sign in Required" Loop
mwpro Jun 20, 2014 12:08 PM (in response to Flemming Rasmussen 123)If you find a fix Flemming - please let me know. However, I am operating Windows 8.1
17. Re: "Sign in Required" Loop
Flemming Rasmussen 123 Jun 20, 2014 12:12 PM (in response to mwpro)I sure will... dont think it's related to the OS. I've tried uninstalling everything with the name adobe in it on my mac and every other suggestion on this and any other thread i can find where people have the same issue... nothing helps - which to me suggests its a serverside (Cloud) problem on Adobe's side...
18. Re: "Sign in Required" Loop
Jeff A Wright Jun 20, 2014 1:04 PM (in response to Flemming Rasmussen 123)Flemming Reasmussen 123 I reviewed your case and your account and I believe you are either facing OPM file corruption or HTTP error handling difficulties. This is due to the extended character within your address. This issue is correctable and I have requested a member of our support team to contact you and review your PDApp.log to determine which error you are facing.
Mwpro I would recommend contacting a member of our support team if you have completed the steps listed in You are no longer signed into your Creative Cloud applications and continue to face difficulties with the sign in process.
19. Re: "Sign in Required" Loop
Flemming Rasmussen 123 Jun 20, 2014 1:12 PM (in response to Jeff A Wright)Jeff I really appreciate your effort in looking into this, since it's very frustrating for me. I should say that deleting the IPM file has been tried both when i had the adobe support on the phone and once again afterwards, but with no luck.
It sounds strange that there should be an error with extended characters in my adobe id / mail address.. it has worked fine for years.
But again - thank you for the effort - hope to hear from your colleague.
20. Re: "Sign in Required" Loop
Jeff A Wright Jun 20, 2014 1:16 PM (in response to Flemming Rasmussen 123)The extended character is actually in your physical mailing address. It should be correctable though once the PDA.log file is reviewed. I don't believe it will be necessary for you to update your account information.
21. Re: "Sign in Required" Loop
mwpro Jun 20, 2014 1:21 PM (in response to Jeff A Wright)Thanks for the response Jeff. I have tried everything as noted. Even did a fresh uninstall/cleaner/reinstall. I have spoken to four separate cs reps and they keep escalating the issue to another rep. No one has contacted me as requested. Everything was fine until I updated yesterday to 2014. Now I cannot access anything. Just a reoccurring Renew your Subscription loop, which is active.
22. Re: "Sign in Required" Loop
Flemming Rasmussen 123 Jun 20, 2014 1:28 PM (in response to mwpro)Exact same issue that I have mvpro - and the adobe support persons i talk with keep escalating the the issue to another rep in my case too.
23. Re: "Sign in Required" Loop
Jeff A Wright Jun 20, 2014 2:30 PM (in response to mwpro)Mwpro can you please post one of your case numbers so I can review the interactions?
24. Re: "Sign in Required" Loop
queen.wild Jun 20, 2014 2:33 PM (in response to Flemming Rasmussen 123)I am having the same problems and have also done everything suggested in this thread and others. I've been without access to any adobe program for 48 hours now. I have also spoken on the phone with adobe support and sent in my logs. I'm still waiting to hear back but am getting increasingly frustrated.
25. Re: "Sign in Required" Loop
mwpro Jun 20, 2014 2:40 PM (in response to Jeff A Wright)I was never given a case number Jeff. I was on chat and they just sent me to four cs reps until the final one said someone will be in touch with you via email.
26. Re: "Sign in Required" Loop
mwpro Jun 20, 2014 2:41 PM (in response to queen.wild)Frustrated is putting it lightly queen.wild. I hate paying for something I cannot use. However, Jeff seems to care and I feel positive he will help.
27. Re: "Sign in Required" Loop
mwpro Jun 20, 2014 2:44 PM (in response to Jeff A Wright)One more thing Jeff. I have tried all the solutions presented. The only thing not working correctly is trying to connect to https://lm.licenses.adobe.com/ through my browsers. No luck. I have no idea how to authorize the site.
28. Re: "Sign in Required" Loop
queen.wild Jun 20, 2014 2:49 PM (in response to mwpro)I hope so. I'm on the phone with adobe again and they have apparently escalated my case - whatever that actually means. And yes, frustration is a mild description of how I'm feeling.
29. Re: "Sign in Required" Loop
mwpro Jun 20, 2014 2:52 PM (in response to queen.wild)Let us know if you find a fix...
30. Re: "Sign in Required" Loop
samanthaterry Jun 20, 2014 2:53 PM (in response to martenme)Also having the same issue with looping sign in screen (running windows 8.1). Have tried the methods suggested here and the "you are no longer signed into Adobe" thread to no avail. Did the uninstall, clean, reinstall for Adobe CC, but still not able to log in. Unfortunately I'm traveling for work and can't spend time on the phone with customer support to resolve the issue until I return home tomorrow.
31. Re: "Sign in Required" Loop
mwpro Jun 20, 2014 3:07 PM (in response to mwpro)Just received a case number Jeff. 0213214192
32. Re: "Sign in Required" Loop
Jeff A Wright Jun 20, 2014 3:14 PM (in response to mwpro)Thanks Mwpro. I have requested a member of our technical support team to contact you directly. You did have an escalation to review the details of your account but from what I can see your account is in good standing.
33. Re: "Sign in Required" Loop
Flemming Rasmussen 123 Jun 21, 2014 12:02 AM (in response to Jeff A Wright)Have anyone of you tried to click the "Start Trial" button when you open a CC app? It atleast gives me acces to the actual app (Ps, Ai, Id) and once I am in, the register/Log in to this account / license this software window reappears and i need to click Start Trial again... Can't get it to work any other way.
34. Re: "Sign in Required" Loop
queen.wild Jun 21, 2014 7:15 AM (in response to Flemming Rasmussen 123)I can't even get to that point. Yesterday adobe tried canceling my subscription and setting me up with a whole new one - still won't work.
35. Re: "Sign in Required" Loop
Flemming Rasmussen 123 Jun 21, 2014 8:00 AM (in response to queen.wild)Seems like Adobe has no clue on what's going on with their software here
36. Re: "Sign in Required" Loop
queen.wild Jun 21, 2014 8:45 AM (in response to Flemming Rasmussen 123)Yep - that's the sense I'm getting too.
37. Re: "Sign in Required" Loop
mwpro Jun 22, 2014 8:30 AM (in response to queen.wild)Did anyone find a fix? I was on the phone with support for over two hours. They had me create a new Windows profile, as they said my old might be corrupted. I was only able to access the software via TRIAL mode. Now I cannot even do that. Support even created a new account to CC - still have the looping error.
38. Re: "Sign in Required" Loop
queen.wild Jun 22, 2014 12:07 PM (in response to mwpro)Nothing yet for me.
39. Re: "Sign in Required" Loop
Jeff A Wright Jun 23, 2014 8:20 AM (in response to queen.wild)Queen.wild I would be happy to review your case if you would like to post your case number.
