in the code you posted there is no code for updating the
db...
plus:
> <CFQuery name = "query1" datasource =
"#APP_DB_DSN#">
> select code , COALESCE(code::text,'') || ':' ||
COALESCE(name,'') as name
> from tblpmdsetcomblist
> where valid_flag = 1
> and id = #id#
> order by sort,code
> </CFQuery>
there is no 'sort' column pulled from the db or aliased by
that name as
it appears in the order by clause in the query above...
> <!--- this is the code that invokes the CFC code
above and displays it as well
> <CFInvoke Component="component.selbox"
Method="Sel_Plusoneflag"
> ReturnVariable="getstr">
you did not post any code for the 'Sel_Plusoneflag' function
in your
cfc... did you post a wrong function or should you change the
method's
name in the cfinvoke?
> i checked all the sources of the problem which are
obvious to me but found
> none :(
and what's the actual problem you are facing? the select box
still not
working (HOW is it not working? - not displaying/displaying
wrong data?)
or something else?
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com
